Old 09-10-2008, 07:19 PM   #1 (permalink)
Default Flashget traces after removal
Hi
I had the latest version of Flashget V1.9.6 installed in my work laptop.
The company I work for has a software that scans the PC's for any software like P2P it did show that Flashget was installed so I uninstall it from the Add and Remove Programs, also deleted the Folder Flashget from the Program Files, also searched the registry for Flasget and Flashg and remove all the reference to them but looks like still some files in the PC.
I rescan the software and shows as the software is still in there.
Is thre a good removal for Flashget or anything else I can do?
THANKS
octron2008 is offline
Old 09-10-2008, 08:15 PM   #2 (permalink)
swatkat's Avatar
Default Re: Flashget traces after removal
There might be some stray FlashGet related Registry entries (which doesn't conatin the string "FlashGet"). Try using CCleaner's Registry cleaning feature to remove these stray entries. You can get CCleaner here:
http://www.ccleaner.com/
http://swatrant.blogspot.com/
swatkat is offline
Spyware Removal vineetrocks2005 QnA (read only) 3 15-01-2009 01:20 AM
Need help with CPU fan removal Abheek Hardware Q&A 14 20-02-2007 09:51 AM
spyware removal sujeet2555 Software Q&A 3 20-02-2006 12:55 AM
How did Anyone Traces the Root ? visvo QnA (read only) 3 06-06-2005 12:15 PM
>>>HELP NEEDED.....FLASHGET REMOVAL PROBLEM<<< maximus999 QnA (read only) 18 14-04-2005 11:51 PM
