I have a P4(3Ghz),512MB RAM & Intel D915 Motherboard
I'm Thinking of upgrading my PC to
A Core 2 Duo Processor and a 2GB RAM.
Now, Im confused about selecting the Motherboard and Graphics Card.
My Budget can't exceed 10k.
Can you provide your options???
I want my PC to run Vista(with all features) and play games decently..
This will cost you around 10K. You can OC this proccy on this mobo to upto 3 Ghz (with stock cooling, no voltage increment), though maybe you should stay safe and OC it upto 2.6 Ghz. And Vista will have no problems with this setup.
Note: This mobo supports only single channel RAM. And you can't use long gfx cards with this board.
heres what i know abt recent some prices for ur config
core2duo-2.4GHz-cost around 5.6k
RAM-Dynite-2GB-1.8k
go for genuine intel motherboard series........i don recommend biostar...
remember one thing whether ur RAM model anf frequency/speed is supported by the motherboard u buy.......that imp
this will come to around 8-9k wihtout graphics card.........but sufficient to run vista smoothly
RAM-Dynite-2GB-1.8k
Never heard of Dynite
And without a gfx card, Vista will be strained, and gaming on Vista will be impossible.
One suggestion, wait...for some time..then save and buy..atleast 15k
He can..but I want him to get a better one..so tht he won't hav to change again in the near future...this way, he'll get better performance....and for a greater amount of time...
