Old 18-05-2005, 12:03 PM   #1 (permalink)
expertno.1's Avatar
Default how to convert a no. of 800x600 images into 80x80 at a click
how to convert a no. of 800x600 images into 80x80 at a click ?
please suggest any freeware
expertno.1 is offline
Old 18-05-2005, 12:27 PM   #2 (permalink)
QA Juggler
saROMan's Avatar
irfanview -> batch Conversion Rename
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 18-05-2005, 01:51 PM   #3 (permalink)
expertno.1's Avatar
thank you it worked
Old 19-05-2005, 01:11 AM   #4 (permalink)
use avtar sizer . using it myself . superb
the genius of the hole : no matter how hard u try 2 get 2 the top , 1 mistake n u start again
mamba is offline
Old 19-05-2005, 01:31 AM   #5 (permalink)
expertno.1's Avatar
from where to get avatar sizer ?
please post a direct download link
Old 19-05-2005, 08:35 AM   #6 (permalink)
I am Optimus Prime
navjotjsingh's Avatar
Download ImageResizer Powertoy for XP from http://download.microsoft.com/downlo...ertoySetup.exe
and use it to resize images on rightclick.
navjotjsingh is offline
Old 19-05-2005, 01:57 PM   #7 (permalink)
Just Do It
Charley's Avatar
Pls give me the link.
Does it means that any pic which is large or medium, can be made smaller as in an avataar, Hun ?
Charley is offline
