Old 18-05-2005, 11:11 AM   #1 (permalink)
Default data cable or IR or bluetooth
hi friends...Couple of days back I bought a new SE T630. I want to do data transfer between my mobile and PC. I have 3 options -
1. Data Cable
2. Infra red
3. Bluetooth
Please suggest which would be the best option (cost vs data transfer speeds). If data cable then is there major performance difference between original SE and some unbranded cable?
Thanks in advance.
ram&byte is offline
Old 18-05-2005, 11:41 AM   #2 (permalink)
I sell so i know
Datacable = i like it as it is fatest and helpful for big data transfer
IR = i dont like it.. too sensitive about direction
Bluetooth = Good , wireless but not recommended for big data transfer.. takes time
I recommend Datacable>Bluetooth>IR
I\'M BACK
khandu is offline
Old 18-05-2005, 02:14 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
I have used all the three, so i can tell
BT is better as far as i am concerned.
-It's wireless
- We can comunicate with other BT phone within 25m range
- Many phone support BT (newer ones), but datacable comes with older phones like 6610,3200, etc...
And IRDa has
- LOS issues
- Slow transfers
So, imo:
BT >datacable >IRDa
drgrudge is offline
Old 18-05-2005, 02:20 PM   #4 (permalink)
Just Do It
Charley's Avatar
Bluetooth is better .... I have used it many a times.
Charley is offline
Old 18-05-2005, 03:57 PM   #5 (permalink)
every1 has a right to expres...
ofcourse.. BT is good..
I\'M BACK
khandu is offline
Old 18-05-2005, 04:24 PM   #6 (permalink)
rohanbee's Avatar
Bluetooth is still numero uno for me...........
Data cable would have to be second and irda is the worst of the lot...........
cheers
Quote by Garfield'
rohanbee is offline
Old 21-05-2005, 10:56 AM   #7 (permalink)
bluetooth is sorta good for normal use ............. but if u r looking for big file transfer......... then u shud get a datacable.............
satbir is offline
Old 22-05-2005, 10:23 PM   #8 (permalink)
Technoholik !!
Tech&ME's Avatar
Bluetooth rocks !!!
Second comes DATACABLE for large file transfer.
Third comes Irda.
Bluetooth benefits :
With bluetooth you can transfer file without (LOS) line of site, which means you can sit in your sofa and control your PC wirelessly.
No hassels when used with Windows XP, no additional drivers required, u even do not require PC SUIT for Nokia phones.
[Desktop]
[Laptop]
Tech&ME is offline
Old 25-05-2005, 03:35 PM   #9 (permalink)
Mr. S Nova
supernova's Avatar
Bluetooth is future ready
My friends keep their phones in the pocket and surf the net using laptop even in the classroom
Knock Knock. Who's there? Opportunity. Can't be, opportunity knocks only once...
supernova is offline
Old 26-05-2005, 07:35 AM   #10 (permalink)
deathvirus_me's Avatar
Its good to have bluetooth in the phone .. but its always better to communicate with the pc through a data cable .....
data cable>bluetooth ....Infra red not recommended at all and should always be your last option ....
deathvirus_me is offline
Old 26-05-2005, 10:47 AM   #11 (permalink)
But since u have a T630, there won't be any large file transfers, so go for bluetooth
Maaxxx, dearest of all my friends!
Abhijit_T is offline
Old 29-05-2005, 02:20 AM   #12 (permalink)
Hi R&B
My choice would be Bluetooth. Simple reason a data cable may and generally does limits you to some phone while with Bluetooth you can use other phone which bluetooth enabled as well.
anupamsinha is offline
