Hi all
I have a 790MB .DAT file in my hard disk... I want to put it in an ISO file and then burn it... Can anyone suggest some usefule software or Can I over burn the CD...
Regards,
Ramprasad
You can burn it using Nero.
If the file is a dat file(VCD file),the file size does not count.Only the length of the movie counts.
If you use a 650MB CD,it has to be 74 min or if u use a 700MB CD it is 80 min.
go to nero...Click Make a VideoCD ..browse to ur dat file..open it...Nero will compile it..and remove any rubbish data and make a vcd out of it.....simple
