Old 18-05-2005, 02:09 AM   #1 (permalink)
jpushkarh's Avatar
Default ! Hibernation Problem !
1. I am using MP3 Flash player since from aug 04.
2. I hav restarted for no of times.
3. Then i tried to update driver but windows says that i hav newest driver. So it failed to update . . .
4. Then i disabled all 6 Generic Volumes But it also does'n work ?
How to solve prb. Hibernation is imp 4 my P !!! 500 pc else it will take time to boot . . .
Thx 4 taking intrest in my prb . . .
jpushkarh is offline
Old 18-05-2005, 04:00 AM   #2 (permalink)
expertno.1's Avatar
why dont't you speed up your boting time ?
expertno.1 is offline
Old 18-05-2005, 11:10 AM   #3 (permalink)
I think this is very serious problem for you as you are posting this at 2:09 AM.
Well the window shows to close the application, so why dont you try closing it and then Hibernate the computer.
You can colse it by opening the task manager.
Choose the appropriate task and right click on it and click END PROCESS.
amolsarode is offline
Old 18-05-2005, 11:22 AM   #4 (permalink)
_mAkA_
Posts: n/a
May be some of your drivers do not support Hibernation..........
Get the latest critical updates and latest updates for your drivers and try again.................
Old 18-05-2005, 01:03 PM   #5 (permalink)
vishal_bhatia87
Posts: n/a
Try to finding the latest drivers for your mp3 player and install it by this:-
Uninstall all the drivers for this device from devicemanager.
restart computer and do not connect the mp3 player.
Then install the latest drivers restart and connect your device.
if you not find any latest drivers write your device full model no. here and I will do it for you.
Old 25-05-2005, 12:59 AM   #6 (permalink)
jpushkarh's Avatar
1. I hv tried to uninstall Genetic Device Driver but they don't Then i disable them > Restart. My 5 of 6 Hdd partation are absent. then i uninstalled them & scan for new hardware My all dhh r returned but same rob.
2. I tried closing all prog from task manager. . .Even all user & local Services
Old 25-05-2005, 02:42 AM   #7 (permalink)
expertno.1's Avatar
get dr salmans window power tools 4.7 and increase your boot up time !
Old 26-05-2005, 01:19 AM   #8 (permalink)
The No.1 Stupid
~Phenom~'s Avatar
hey guys, can anyone gimme the sol. of my problem.
whenever i hibernate my PC , it takes almost five long minutes to hibernate while all my friends hibernate their PCs in less than a minute.
can anyone tell me the reason?????
please help
n00b forever...
~Phenom~ is offline
Old 26-05-2005, 08:58 AM   #9 (permalink)
expertno.1's Avatar
you have inappropriate device drivers installed !
