Old 02-09-2004, 02:17 PM   #1 (permalink)
Default Monitor trouble
Hi guys..
I have a Microtek 15" monitor, it was working fine,
but from last 6 -8 dayz it was giving delay in starting, ie after starting nothing appears on screen for few minz, that time goes increasing and today nothing has appeared from last 3 hrs,
Well I kno I have to now goto service center , but before that I wanna know that wht could be the problem ?
ONe more thing !! sometimes it automatically changes the color of screen (ofcourse when it was working) , changes the color of screen as cable is loose but cable is fine.. and then automatcally get to normal !!
So guys plz suggest me wht could be the problem !!
and also hw much service center guy can charge for it ?
wAiting..
~Ricky
» Looking for someone to partner with me in Indian Linux forum
Free domain is available ! I am also at Indian Forums.
Ricky is offline
Old 02-09-2004, 08:09 PM   #2 (permalink)
Haddd. ho gayi.. no body even have a clue ?
~Ricky
Ricky is offline
Old 02-09-2004, 08:27 PM   #3 (permalink)
Let the music play.....
djmykey's Avatar
Yo either its monitor cable is gone. Its not much of a costly affair. But if the monitor is not turning on and that time is increasin steadily then man ur in deep sh!t then go to a service center u trust coz in a problem like this there is a tendency to say that the EHT is gone and the put a heafty bill on ya so go see it. And man i need ya help man gonna make a project in Linux so pls help me can ya pm me at michael_kale_in@yahoo.com
djmykey is offline
Old 02-09-2004, 08:30 PM   #4 (permalink)
I had similar problems with one of my monitors, delayed start, screen turned green at times. The technician told me that it was some kind of a minor electrical problem. Your picture Tube etc. is probably fine, I think you may have to spend upto 500 on repairs.
wORm is offline
Old 03-09-2004, 09:49 AM   #5 (permalink)
GameAddict's Avatar
Default Something same happened here...
Hi,
I came across a similiar problem few weeks back. Monitor was showing a green tinge all over the scree.Had to go for repair (Rs.350/-).Some soldering was loose.It's working fine now!
GA
GameAddict is offline
Old 03-09-2004, 04:11 PM   #6 (permalink)
pedal to metal
suave_guy's Avatar
The green screen u guys are talking about happends/occurs due to the presence of magnetic field around/near the monitor like unshielded speakers/subwoofers and the cure is to degauss the monitor screen. Most of the newer monitors have this option to degauss the screen and this should be done only once within 30 mins. to avoid any damage.
If you dont have the degauss feature then just leave the monitor and it will be back to normal colors after sometime.....You shud also place ur speakers at some distance from the monitor to avoid such problems.
As far as the delay in displaying the screen is concerned i think there's a problem with electron gun which is causing the delay in the electron eruption which in turn is delaying the warming up of the screen, and hence the delay in the display of the screen.
I'm not too sure though....this is just a guess/estimate
Enjoy
your "attitude" is your best friend...
suave_guy is offline
Old 03-09-2004, 04:35 PM   #7 (permalink)
suave_guy, the green screen we are talking about is not due to the tube getting magnetised. Its a power problem that makes horizontal green lines appear on the screen, unlike blotches which appear after the tube gets magnetised. Deguassing doesn't help.
wORm is offline
Old 03-09-2004, 10:15 PM   #8 (permalink)
Seems to be my case but they were not lines..
Well will go tomorrow to service center !
~Ricky
Ricky is offline
Old 04-09-2004, 04:17 PM   #9 (permalink)
pedal to metal
suave_guy's Avatar
Thanks for correcting me worm....Well the magnetising of picture tube also causes the green patches and thats what i presumed....
Enjoy
Old 05-09-2004, 01:34 AM   #10 (permalink)
i also have a problem with my monitor
in the past few days. at random intervals my monitor flickers, britens and then acts like i degaussed it. it happens only sometimes. what do you think is the problem? it's happened about 5 times in the last 3 days. i keep my comp on 24/7.
also the problem happens both on linux and 98 so it's not a driver problem.
Regards,
Gaurav
gaurav_018 is offline
Old 05-09-2004, 07:56 PM   #11 (permalink)
well its simple
its a monitor problem
whatever it is .. service it .. or get rid of it as fast as u can
it just gets worse
No Mercy, No Limits.
theraven is offline
Old 06-09-2004, 10:55 AM   #12 (permalink)
busyanuj's Avatar
the "green" tinge appears if one or some of the pins ( that connect the monitor wire to the back of the cabinet) are broken and need soldering.
busyanuj is offline
