Old 06-10-2008, 11:58 PM   #1 (permalink)
Be Healthy, Keep Smiling
Kaushal Hiwarkar's Avatar
Default F:\ is not accessible
Friends Plz help me . F: drive is my working directory .I have important data in that drive . I was printing data through f: drive after finishing my job i have closed that drive. Then again after 1 minute or less I tried to open F: dirve ,It doesn't open instead of opening I am getting following message. Friends Plz tell me the cause and solution. I will ve very thankful to all of U.
The file or directory is corrupted and unreadable
In property it shows Used Space 0 bytes, Free Space 0 bytes. Do I have to format that drive.
Kaushal Hiwarkar is offline
Old 07-10-2008, 01:32 AM   #2 (permalink)
swatkat's Avatar
Default Re: F:\ is not accessible
Right-click on F:\ drive icon in Windows Explorer, and choose "Properties" option. Here, click "Tools" tab and click "Check Now" in error-checking section. Hopefully, it will detect any filesystem errors and fix it, so that the partition can be used again!
If that does not work, then you can use PC Inspector File Recovery to recover files:
http://www.pcinspector.de/Sites/file...htm?language=1
http://swatrant.blogspot.com/
swatkat is offline
Old 07-10-2008, 09:21 AM   #3 (permalink)
Thanks a lot "Swat cat " I have successfully loged in that drive Thanks a lot.
Now one more question, What will be the cause/ reason
Old 07-10-2008, 09:33 PM   #4 (permalink)
swatkat's Avatar
Glad to know that helped That error was probably due to some sort of file corruption. It may not exactly result in data loss. Probably, some sort NTFS file index corruption, which can be fixed by running an "Error Check"...
swatkat is offline
Old 09-02-2009, 06:31 PM   #5 (permalink)
I faced the same problem on my USB hdd. its a hitachi 80GB laptop hdd running over usb.
I checked the disk. Disk checker shows it found no errors and shows around 54GB in use. But i still cant access it from anywhere.not even cmd.I use vista ultimate. please help people.it has a lot of crucial data.
If you can't beat your computer at chess, try kickboxing.
vutonium is offline
Old 09-02-2009, 11:20 PM   #6 (permalink)
In search of light...
abhi.eternal's Avatar
^^try ubuntu live dvd. if the files are still there, you can copy them to your main hdd
http://abhijeetdeb.com
abhi.eternal is offline
Mcp site not accessible techx Chit-Chat 15 17-05-2008 04:01 PM
drives not accessible vipinkumarsolanki Software Q&A 7 07-03-2007 10:22 PM
Help Usb Hd Not Accessible!!!!!! utkarsh_kusd Hardware Q&A 1 24-07-2006 03:50 AM
workgroup not accessible naveenpoddar QnA (read only) 3 09-04-2005 10:22 AM
