Old 05-10-2008, 03:38 PM   #1 (permalink)
ajayritik's Avatar
Default The Mic port in front of the cabinet not working
I'm unable to use the Mic port that is located in front of the cabinet. Is there any kind of connection that I need to check on the motherboard? I tried to open the cabinet and check for the wire connections but everything looked hazy to me. Do I have to look at the motherboard manual for this? Please help me out. I'm having trouble connecting my mic to the back of the cabinet. The port for connecting headphones at the front of the cabinet is working. It's only the mic front port which is not working.
ajayritik is offline
Old 05-10-2008, 03:42 PM   #2 (permalink)
hell boy
Default Re: The Mic port in front of the cabinet not working
yea, which motherboard are u having!!!
and does the front headphone jack on ur cabinet works fine????
and does the front headphone jack on ur cabinet work fine????
like sly stallone i am bringing the pain the only difference is that i got SINGH in my name..,!!
MasterMinds is offline
Old 05-10-2008, 11:59 PM   #3 (permalink)
Has it stopped working suddenly? If you have the diagrams of the various connections on
the mobo you can check the mic connections. Intel boards do come with this diagram. It mmay also be that there is a loose connection in the jack.
nmenon is offline
Old 10-10-2008, 09:14 PM   #4 (permalink)
ajayritik's Avatar
Intel DG965 RY
The front headphone jack on my cabinet works fine
Why did you ask me this question twice?
No, it's not working from the beginning! Yes I think I need to check that diagram out. I don't know where I placed that motherboard diagram.
Old 10-10-2008, 10:54 PM   #5 (permalink)
a_g = JPKN
s18000rpm's Avatar
i've dg965wh m/b
when i connect the headphone at Front Port (FP), both the headphone and speaker work . mic. doesnt work (not a problem, as i use rear port for it, USB's work fine)
i've Zebronics AntiBiotic cabinet.
te connection is correct, reffered both cabinet manual as well as m/b's
ASUS K53SV SX520D + BF3
s18000rpm is offline
front USB are not working hrushij Peripherals 2 30-03-2007 10:25 AM
Making Front USB ports in the Cabinet working sknowonweb Peripherals 5 15-11-2005 02:11 PM
Front USB port not working sohin Peripherals 3 05-09-2004 03:27 PM
