Old 17-05-2005, 06:02 PM   #1 (permalink)
Distinguished Member
anandk's Avatar
Default Rename your RECYCLE BIN !!!
Guys, heres an interesting tweak i came across.
heres how you can rename your recycle bin, just for fun !
Open the Registry Editor (click start>run>regedit>ok).
go to (use edit>find if u wish):
[HKEY_CLASSES_ROOT\CLSID\{645FF040-5081-101B-9F08-00AA002F954E}\ShellFolder]
CallForAttributes=0x00000000(0)
Attributes=50 01 00 20
First double click on the CallForAttributes key and change its value to 0.
Then double click on the Attributes key & change its value to 50 01 00 20
this adds a Rename option to the Recycle Bin icons context menu.
now when u right click on your recyle bin, u will find a rename option.
change it to Dust Bin, if u like !
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 17-05-2005, 06:19 PM   #2 (permalink)
expertno.1's Avatar
LOL ! i knew it
you can also use xteq systems
expertno.1 is offline
Old 17-05-2005, 06:33 PM   #3 (permalink)
Good one man. But i already knew that. But anyways Thanks and keep posting such tweaks
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 17-05-2005, 06:35 PM   #4 (permalink)
knewwwwww it looooooooooooonnnnnnnnnnnnnnngggggggggggggggggg back! newayzz thanks!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 17-05-2005, 06:49 PM   #5 (permalink)
ashisharya's Avatar
Default Kooooool PosT mAN!!!!!!!
Keep Posting These GooD Tricks!
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
ashisharya is offline
Old 17-05-2005, 07:54 PM   #6 (permalink)
I didnt knew about it, but this tweak was present in April Autopatcher
Shwetanshu Srivastava
shwetanshu is offline
Old 17-05-2005, 08:14 PM   #7 (permalink)
Location: The throne at the royal palace of Smiley Kingdom!
Hmmm.. Lemme see
On what part of muh brain was it
Oh, got it
Just get "Desktop UI Renamer"
~175 KB < DL link >
:) [_CALCATIAN_] :)
Status: Online [ ] / Offline [ :( ]
\"I sleep 4 only 2.5 Hrs/week & doc.s say I\'m fine :!: \"
Everyone SUX in their own comfortable way :!:
Calcatian is offline
Old 17-05-2005, 09:32 PM   #8 (permalink)
There are easier ways to perform the same task(Of course using 3rd party software like system mechanic,X Setup etc)
But doing it the hard way really is fun.
Keep posting.
amitsaudy is offline
