Old 17-05-2005, 05:42 PM   #1 (permalink)
Default saving web pages
hi guys i want to know whether there are any free softwares which allow u to save web pages along with the links and animations
imported_renault is offline
Old 17-05-2005, 06:48 PM   #2 (permalink)
Location: The throne at the royal palace of Smiley Kingdom!
yes there is - it is known as "Internet Explorer"
Just save the page as complete web *.mHt
:) [_CALCATIAN_] :)
Status: Online [ ] / Offline [ :( ]
\"I sleep 4 only 2.5 Hrs/week & doc.s say I\'m fine :!: \"
Everyone SUX in their own comfortable way :!:
Calcatian is offline
Old 17-05-2005, 10:10 PM   #3 (permalink)
Yeah
Its as simple as that.
But if want to save an entire website for offline viewing then use 'web copier' or google it.
amitsaudy is offline
Old 17-05-2005, 10:35 PM   #4 (permalink)
Tux
Posts: n/a
In firefox just goto FILE>>SAVE PAGE AS..
Itll save all anim and pics
Old 17-05-2005, 11:00 PM   #5 (permalink)
But the result will not be just 1 file
So here is another shortcoming Linux users have to cope up with
ThanX m8
And renault, 2 rip a whole site u can use HTTrack / GetLeft (Free)
By the way - at least 3 ppl in this board are using the same avatar as you - who ripped whose
:) [_CALCATIAN_] :)
Old 17-05-2005, 11:45 PM   #6 (permalink)
Default BUT
but saving using I E is tedious(for the entire site) and sure is crappy,i mean after about days or if i open the file in some other pc it doesnot show the animations and the like.This may sound silly but believe me i have experienced this.
AND I NEED A FREE PROGRAM
Old 18-05-2005, 08:56 AM   #7 (permalink)
Biplav's Avatar
i will tell u- use opera (latest version ie. 8) and when u are in the page u have to save- jush press
Ctrl+ S
and in the "save as type" make it html with images.
as simple as that
Biplav is offline
Old 18-05-2005, 01:28 PM   #8 (permalink)
Just Do It
Charley's Avatar
Default Re: BUT
For that you could use softwares which download the entire website, which u could use to view offline later.
Charley is offline
Old 18-05-2005, 02:27 PM   #9 (permalink)
144
144's Avatar
Go to the following Site and download HTTrack.
www.httrack.com/
With HTTrack it will download each page of the site you want to download automatically.. But I dont think it will work on dynamic pages.
On a long enough timeline, the survival rate for everyone drops to zero
144 is offline
Old 18-05-2005, 09:11 PM   #10 (permalink)
Default Re: BUT
U didn't mention ripping the whole site at first, did u
MHT files r not viewable in older IE versions, which wud change soon as more & more ppl use Me/2K/XP+.....
anyway, my 2nd post coverd yor need
GetLeft - Good (slower)
HTTrack - KooooL
got it
:) [_CALCATIAN_] :)
Old 18-05-2005, 09:13 PM   #11 (permalink)
Just Do It
Charley's Avatar
Default Re: BUT
HTTrack - KooooL
got it
Man ur an emoticon freak. All ur text filled with it.
Charley is offline
Old 18-05-2005, 09:37 PM   #12 (permalink)
Finally, some1 got it
I AM the king of Smiley Kingdom!
:) [_CALCATIAN_] :)
Old 18-05-2005, 11:04 PM   #13 (permalink)
rajat22's Avatar
Default MHT Quick Saver 3.0 for MS IE
Certainly there is other than brwsers, I am using it. Try this
MHT Quick Saver 3.0
Source:http://www.fileheaven.com/
What is MHT Quick Saver?
"Quick MHT saver for MS IE."
MHT Quick Saver Description from the Publisher
The program provides instant saving of any web page on view in MS Internet
Explorer in any of supported formats. This includes the 'MHT' single file
format. Instead of executing a lengthy sequence of operations - open the
menu 'File', choose the 'Save As...' directory, enter a new filename and
press the 'Save' button - you simply click on the Quick Saver icon on the MS
IE toolbar or press a single hot key. MHT Quick Saver does the rest.
Its a shareware.
Screenshot
Download
http://www.fileheaven.com/download.a...load/MHTQS.zip
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 19-05-2005, 07:38 AM   #14 (permalink)
expertno.1's Avatar
use offline explorer pro to save or to download all the websites
expertno.1 is offline
Old 19-05-2005, 01:02 PM   #15 (permalink)
Just Do It
Charley's Avatar
Ive tried this software but it omits most of the links, pages , etc......
Charley is offline
Old 19-05-2005, 02:33 PM   #16 (permalink)
rajat22, does MHT Quick Saver 3.0 rips whole sites 2 make 1 .mHt Heard bout this coz it was released in the scene 1 years back by a pal of mine... havnt tried it though
:) [_CALCATIAN_] :)
