Old 04-10-2008, 11:28 AM   #1 (permalink)
prabhu.wali
prabhu.wali's Avatar
Arrow 1 GB of less RAM!!!!!!!
Hey, i have a intel G35EC motherboard n i've got 4GB DDR 2 800mhz of memory,though my BIOS shows 4GB of memory,my system info tab shows me only 3GB of RAM.i am using windows xp professional SP2
prabhu.wali is offline
Old 04-10-2008, 11:31 AM   #2 (permalink)
M3TAL H3AD M3
skippednote's Avatar
Default Re: 1 GB of less RAM!!!!!!!
Seems you are using Windows XP 32 bit edtion
So this version supports 3gigs of RAM
Better get vista 64 bit version as the XP 64 bit edition is less compatible with softwares.
I spit Rainbows.
skippednote is offline
Old 04-10-2008, 11:33 AM   #3 (permalink)
prabhu.wali
thanks for ur reply
Old 04-10-2008, 11:37 AM   #4 (permalink)
M3TAL H3AD M3
Welcome....
I spit Rainbows.
Old 05-10-2008, 12:12 PM   #5 (permalink)
Cool Buddy's Avatar
do you have a dedicated graphics card? if not then your RAM might be shared with your onboard graphics. you can check this in the BIOS. generally it is under advanced settings. you can reduce it to 512MB or less if you want.
Nokia 5230 :(
Canon IXUS 115 HS :)
Cool Buddy is offline
Old 05-10-2008, 12:19 PM   #6 (permalink)
Violent serenity.
Psychosocial's Avatar
^This aint the case here.
@OP
bassam is right. 32 Bits OSes only support upto 3GB RAM. Only a 64Bit OS can use the full potential of your 4GB RAM.
Psychosocial is offline
Old 05-10-2008, 12:21 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
no itz not that here^^^^
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 05-10-2008, 05:10 PM   #8 (permalink)
prabhu.wali
i do have dedicated 9600gt graphics card
Old 05-10-2008, 05:39 PM   #9 (permalink)
The Black Waltz
No problem dude. It's not due to the graphics. Upgrade to XP 64 bit.
#krow @ irc.freenode.net
Cool Joe is offline
Old 05-10-2008, 11:08 PM   #10 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Dun worry..u'll get commendable performance....if it bothers u...then upgrade to 64-bit
About me:
Old 06-10-2008, 01:07 AM   #11 (permalink)
IronMan; Ready to Roll...
IronManForever's Avatar
XP 64 bit is passe. Less support/apps. I have heard people being unhappy with Xp64bit.
Isnt Vista Home premium 64bit available?
Why not use 64bit Linux(Ubuntu/openSUSE) for crtitical tasks for now and buy 64bit windows vista later if you want. Plus you get Linux for free.
Aluminum MacBook 2.0GHz Collector's Edition
Windows Box: 2.26G P4, 1GiB RAM, 320GB SATA + 80GB PATA HDD, Nvidia FX5200
AOC Fovi F22
iPod Touch 16GiB, HTC Gene, Moto W230, Sansa Express
IronManForever is offline
Old 06-10-2008, 10:33 AM   #12 (permalink)
Violent serenity.
True...
