Hi. I modified a .exe file to what I need for it to say. I basicaally only changed the words and the icon.
I wonder if its possiable to change the color/layout of the .exe file. For example. Change the background color? Change the words color?
Also I wonder if its possiable to add a picture on the .exe for. For example. If you open a .exe file and you see like your avatar in the coronr of the window. Not the icon. I want to know how to add a picture.
Ya u can edit images if they are available as resources
U can put your own image instead
U can also change the location of that if the things aren't locked
Basically it depends upon what r u editing
I case of .exe its not generally possible since they are compressed to prevent cracking
Depends on the exe - packed or unpacked, what language its coded in, etc.
