Old 17-05-2005, 02:08 PM   #1 (permalink)
Default soundcard problem how to solve it?
When i start winamp the messaga sees " MMSYSTEM002 error. device is out of frequency "
What i have to do to solve this problem?
I can't here any sound in computer.
vishnu is offline
Old 17-05-2005, 02:43 PM   #2 (permalink)
vishal_bhatia87
Posts: n/a
The message also comes with windo media player?
Which operating system you are using?
Internal onboard sound or using soundcard?
Answer these questions and write your computer
configuration then only I can help you!
Old 17-05-2005, 04:29 PM   #3 (permalink)
expertno.1's Avatar
oh this is the old message which i had got when i buyed the computer
install your sound drivers properly and get the latest update of WMP
this solved my problem
expertno.1 is offline
