Old 30-09-2008, 01:00 PM   #1 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
Default Quicktime movies ! ! !
i have installed latest k-lite codec pack from digit dvd .... rest of the vids r played smoothly bt quicktime movies [.mov] play frame-by-frame .... trailers from digit dvd & some downloaded .mov files have same effect ...... y is it so ?
... W H O T ...
ax3 is offline
Old 01-10-2008, 09:39 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: Quicktime movies ! ! !
Reinstall quicktime lite from k-lite website.
dheeraj_kumar is offline
Old 02-10-2008, 04:25 PM   #3 (permalink)
ax3
ax3's Avatar
it doesnt help .... still getting fram-by-frame ......
... W H O T ...
ax3 is offline
Old 02-10-2008, 05:34 PM   #4 (permalink)
God of Mistakes...
Garbage's Avatar
Try playing in another player to see whether its "particular to player" problem.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 03-10-2008, 11:39 AM   #5 (permalink)
ax3
ax3's Avatar
yup ....... its working with windows media player ........
... W H O T ...
ax3 is offline
Old 01-11-2008, 03:53 PM   #6 (permalink)
ax3
ax3's Avatar
now i have a new problem ...... whenever i click on any video file [all formats] my pc hangs & just reboots ......
any idea whot is it ?
... W H O T ...
ax3 is offline
Old 01-11-2008, 04:52 PM   #7 (permalink)
Reinstall directx?
Old 02-11-2008, 11:03 AM   #8 (permalink)
ax3
ax3's Avatar
bt will it really help ?
... W H O T ...
ax3 is offline
Old 02-11-2008, 01:14 PM   #9 (permalink)
Well, we wont know until you try, will we?
Old 03-11-2008, 11:04 AM   #10 (permalink)
ax3
ax3's Avatar
bt i didnt installed it after i a fresh OS install as sp2 had it ..... then wont it conflict ??
& which digit cd\dvd has latest directx ???
... W H O T ...
ax3 is offline
Old 03-11-2008, 12:25 PM   #11 (permalink)
No it wont. Get it from microsoft's site - August 2008 edition.
Old 03-11-2008, 04:05 PM   #12 (permalink)
ax3
ax3's Avatar
thanx ...... bt installed nvidia drivers & they were causing the conflict ...
bt still trailers from digit dvd [quantum,terminator etc]wont play smooth ???
... W H O T ...
ax3 is offline
Old 05-11-2008, 11:24 AM   #13 (permalink)
ax3
ax3's Avatar
so no1`s facing problem regarding HD-trailers from digit dvd ???
... W H O T ...
ax3 is offline
Download Quicktime 7.3.1.7 marulez Technology News 12 19-12-2007 12:44 AM
quicktime seven issues shaunak Software Q&A 5 11-01-2006 06:56 PM
How to save movies in quicktime Sankalp QnA (read only) 5 26-09-2005 10:10 PM
Software for editing Quicktime movies milganz Software Q&A 7 23-01-2005 01:29 PM
How to d/l quicktime streaming movies killerguy QnA (read only) 1 06-01-2005 11:38 PM
