Old 17-05-2005, 01:01 AM   #1 (permalink)
NikhilVerma's Avatar
Default Can't see Process's User Name...
Hi!
Recently I am getting this very wierd problem...
I can't see the user name of services in Task Manager....
Is this a virus ?
This is a small problem so I posted it in general section....
NikhilVerma is offline
Old 17-05-2005, 03:56 AM   #2 (permalink)
expertno.1's Avatar
have you restarted your computer and checked it again?
this not a virus
have you checked it with nav
you need not needed to post such a bigger picture
please reply an then we could answer
expertno.1 is offline
Old 17-05-2005, 04:40 PM   #3 (permalink)
This problem is there for over one week now... So the PC's been restarted 7*2 = 14 times now...
If this is not a virus ... then why check with nav? BTW I use KAV.....
Picture removed....
Reply given
Old 17-05-2005, 06:25 PM   #4 (permalink)
mekalodu
iinfi's Avatar
ctrl + Alt + Del
select Process TAB
select View frm menu bar >> select Columns
u can select which columns u want frm here
i hope this is what u want ....
mekalodu
iinfi is offline
Old 17-05-2005, 06:29 PM   #5 (permalink)
Check for virus or spyware... th'is could be dangerous spware. use adaware and also check for viruses
www.digizeal.org
Tech support + JAVA and Cisco dedicated subforums..
Come and check
anubhav_har is offline
Old 17-05-2005, 10:16 PM   #6 (permalink)
Originally Posted by iinfi
ctrl + Alt + Del
select Process TAB
I have done that ..... Actually I have a "User Name" tab..... But it doesn't display any names! Which is so wierd..
There are no spywares too !
Old 18-05-2005, 12:51 AM   #7 (permalink)
mekalodu
iinfi's Avatar
run > services.msc > terminal services > start this service (make it start automatically)
try this ... it mite help
mekalodu
iinfi is offline
Old 18-05-2005, 03:48 AM   #8 (permalink)
expertno.1's Avatar
repair the xp form the installation disk and then try and post here
Old 18-05-2005, 12:48 PM   #9 (permalink)
Thanks Man! That did it!
