Old 02-09-2004, 10:07 AM   #1 (permalink)
slugger's Avatar
Default connect P.C. to Television
Hey folks plz help me out. I would like to know if there is any way by which I can connect my Computer to my Television so that I can watxh the videos on my HDD on the big screen (29" screen). Also can I watch movies through the VCD running in the CD drive on my television.
If I need to add xtra HW to rig up my T.V 2 my P.C., plz quote its approx price (so that I don't get taken 4 a ride)
slugger is offline
Old 02-09-2004, 11:10 AM   #2 (permalink)
search and thou shalt receive its fruits !!
No Mercy, No Limits.
theraven is offline
Old 02-09-2004, 11:16 AM   #3 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
U need a graphics card with a TV-out port. Search the net for prices and available models.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 02-09-2004, 11:33 AM   #4 (permalink)
Ethan_Hunt's Avatar
Try for a Geforce Fx series Graphics card with optional Tv out connection or composite S-video out it will help u get better clarity and will also be able to watch dvd or vcd movies at a good resolution OR Try and opt for a Tv tuner card which has a Tv-out connection it might not give as clear image as a Graphic card but is less costly compared to a graphic card it must be costing around 1,800 bucks whereas a graphic card can cost u around 5,000 bucks (a good one with 128 MB Geforce one).well just to make sure of the prices just ask a lamington road dealer or visit diff shops over there.good luck.peace.
Ethan_Hunt is offline
Old 02-09-2004, 06:19 PM   #5 (permalink)
use a vga to composit converter. we use it to hook up five to ten tv during a large presentation and it is quite cheep about rs 1500/- also there is no need to open the computer box just connect it to the vga out and it gives a composit vidio signal that can be feed to the av socket of the tv.
**** happens
pradeep_chauhan is offline
Old 02-09-2004, 07:46 PM   #6 (permalink)
hey guys i have a geforce mx 440se and when i connect the card to the comp nothing happens...should i select the Tv as a primary display or juts keep it as a secondary one...
its my gift....
its my curse....
who am i??
i`m spiderman....2!
godzi_85 is offline
Old 02-09-2004, 08:07 PM   #7 (permalink)
King of my own Castle
freshseasons's Avatar
What do u mean by tha..u mean when u inster Card into AGP slot nothing happens .....
Anyway choose TV as secondary monitor...but better if there is an option choose Clone mode .
freshseasons is offline
Old 02-09-2004, 09:42 PM   #8 (permalink)
sigh
ok ... lets get into this
1) @slugger i dont suggest u go for tv tuners with tv out ...
so go in for a graphics card with a tv out or try out pradeep's way its cheaper ...
2) @godzi
ok i guess uve inserted ur card into the agp slot ... and ur monitor is workin fine
now u have to goto ur display properties => settings => advanced
and click the appropriate tab for the displays ...
now make sure ur tv out is connected or the "tv" display will not be highlighted
now choose the tv instead of ur analog monitor as the display
and make sure the country/region in its settings is set on india or the output format is pal-B.
click ok to apply and see if it works ... or else it'll be reset in 15 seconds anyways .. no harm no foul !
theraven is offline
