Old 26-09-2008, 11:39 PM   #1 (permalink)
evewin89's Avatar
Default sony dvd drive tray is not opening?
I opened my sony dvd drive for cleaning its lens & after cleaning,I attached it back 2 the p.c but now its tray is not opening & its light is glowing all the time, guys plz help.
Evil Lives 4ever......
evewin89 is offline
Old 27-09-2008, 07:25 AM   #2 (permalink)
The Black Waltz
Default Re: sony dvd drive tray is not opening?
Well.... I think you made a booboo when you were cleaning the lens. Contact Sony customer care and tell them that the drive tray is not ejecting and the light is always glowing. Don't tell them that it happened after you cleaned the lens. They should believe you.
#krow @ irc.freenode.net
Cool Joe is offline
Old 27-09-2008, 07:39 AM   #3 (permalink)
U opened it to clean the lens? :O well, the service centre guys will know it as soon as they look at it... no point in bluffing. But, Give it a try.
I think the cable didnt fit in right, check it out first. Clean the connector too.
\"Still waters run deep\"
\"I smile in the dark .......\"
Scorpion is offline
Old 27-09-2008, 11:18 AM   #4 (permalink)
java is fun.
digitalage's Avatar
in my opinion u might have removed the belt which drives the tray in and out or might be gears are jacked from their position..... if u r not a expert plz do contact the customer care for services...
digitalage is offline
Old 27-09-2008, 06:03 PM   #5 (permalink)
evewin89's Avatar
Thanks 4 ur replies…. Now I m able 2 open the tray smoothly (only without metal cover) but as soon as I cover the drive wit its metal cover,the tray is not opening. I think the metal cover is not allowing the tray 2 open, I hav already checked more than 10 times which part of the metal cover is stopping the tray 2 open but I m not able 2 solve the peoblem
evewin89 is offline
Old 30-09-2008, 01:13 AM   #6 (permalink)
java is fun.
digitalage's Avatar
difficult to figure it out from here ... it will be a help if u post a closeup pic of ur drive without metal cover...
Sony DVD-RW tray not working properly.. Ashok Verma Hardware Q&A 10 02-12-2008 01:18 AM
Drive Tray !!! bajaj151 QnA (read only) 2 22-03-2007 02:25 AM
CD-RW Tray not opening VexByte Hardware Q&A 21 27-02-2007 09:20 AM
CD Drive Tray doesnt come out Manshahia Hardware Q&A 16 22-01-2007 01:10 PM
CD-ROM Drive tray Not opening slugger Hardware Q&A 5 29-12-2005 09:13 AM
