Old 26-09-2008, 02:12 PM   #1 (permalink)
Default needa help for compressing
hi guys
recently i came across many winrar file which are of very less size n on extraction it give a vry big file....its not from kgb archive just simple winrar....can anyone tell me the method so that even i can do it???
these file are generally of iso type
i wana compress my movie collection like this
ashishstillthere is offline
Old 26-09-2008, 09:27 PM   #2 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Default Re: needa help for compressing
Movies are already compressed. That ISO may not be. Compression depends on the type of content, and this wont work on movies, sorry to burst your bubble
dheeraj_kumar is offline
Old 27-09-2008, 10:43 AM   #3 (permalink)
parthbarot's Avatar
hmm...winrar or 7zip can be used for best compression,but its only upto specific contents like text,docs,htmls etc... which can be compressed in a very less size then you expect.
But movies,MP3s and other media files are compiled and already compressed in specific format.so no need to compress them using winrar or KGB etc. because that content can't be compressed more.I think...even winrar can't understand that kind a format
today mostly AVI (Divx/Xvid/Mp4/X264),Mp3 etc files are used for media,which are heavily compressed by the codecs used for generation.
i hope this helps you.
regards.
www.techlads.com
Paarth.
parthbarot is offline
Old 27-09-2008, 11:09 AM   #4 (permalink)
java is fun.
digitalage's Avatar
^ +1 to the this.
digitalage is offline
Old 28-09-2008, 07:33 AM   #5 (permalink)
The Black Waltz
Yep, compressing audio or video files using any format doesn't reduce the file size significantly. I've personally tested this.
#krow @ irc.freenode.net
Cool Joe is offline
Old 02-10-2008, 05:27 PM   #6 (permalink)
thanks 2 all for valuable reply
than any other way to save my disk space by movies
n vat about the other software which are in exe format n packed in special way like 1st via winrar then in folder then again compressed via rar/zip n all n the resultant file comes out very smoll n when extracted it becomes very large....(some time they are of bin/cue format)
Old 04-10-2008, 01:11 PM   #7 (permalink)
Check the sizes of the rar and the zip - maximum difference will be 1 mb or so...
Old 06-10-2008, 11:48 AM   #8 (permalink)
parthbarot's Avatar
Easiest way to reduce size for media is...reducing the quality..but i dnt think u would like it..so..better burn media on DVDs .
and no other compression (Other than codecs i mean.. ) helps you.
regards.
www.techlads.com
Paarth.
Old 06-10-2008, 02:19 PM   #9 (permalink)
no dheeraj i have one rar file whch has iso of 6 window xp n its of just 9.smthing mb in size and on extraction it give more than 3 gb of file n on burning it give 4gb+ size now u tell me how its possible
its not of kgb
Old 07-10-2008, 08:09 AM   #10 (permalink)
^^ I cant answer that, I've downloaded a Vista Floppy Disk edition, 1.4 MB, and it expands to a dvd.
Old 07-10-2008, 12:43 PM   #11 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Beware..it'll take long time to compress movies etc..(longer than uncompressing)
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 07-10-2008, 01:29 PM   #12 (permalink)
The Black Waltz
How can this sort of compression be done??? My friend told me about having a copy of GTA SA which was under 5 MB and I lolled at him. Now that you've said it, I've no choice but to believe it. How is it possible??
Cool Joe is offline
Old 07-10-2008, 01:54 PM   #13 (permalink)
Its via KGB archiver. Vista Ultimate + Office 2007 = 4.5 MegaBytes.
Old 07-10-2008, 01:58 PM   #14 (permalink)
~Beating Toughest Games~
pc_game_lover2004's Avatar
it takes a hell lot time compressing and extracting
PKG
My Rig :-Intel(R)Pentium(R)DualCPU E2160@1.80GHz, 2046MB RAM, 500 GB HDD, NVIDIA GeForce 8600 GT, Windows Vista™ Ultimate, Asus P5N-MX Motherboard
pc_game_lover2004 is offline
Old 07-10-2008, 02:02 PM   #15 (permalink)
^^ like a day or two.
Old 07-10-2008, 02:02 PM   #16 (permalink)
Yeah very less isn't it....
PKG
Old 07-10-2008, 02:29 PM   #17 (permalink)
The Black Waltz
Yeah thanks Dheeraj for that. Downloaded it now. For those who want it- http://sourceforge.net/project/downl..._mirror=switch
Cool Joe is offline
Old 07-10-2008, 02:49 PM   #18 (permalink)
Fullbring
Zangetsu's Avatar
KGB is a time consuming app...but has amazing compression ratio...i once found
"Lage Raho Munnabhai" movie size: 1MB
Zangetsu is offline
Old 07-10-2008, 08:11 PM   #19 (permalink)
i too have that filr dheeraj but many other files are not from that kgb type....can u tell me other way to do so???
Old 07-10-2008, 09:14 PM   #20 (permalink)
I dont know anything else.
Old 07-10-2008, 09:39 PM   #21 (permalink)
The Black Waltz
OMG... This thing takes a damn long time to compress.... On my AMD 64 1.81 Ghz with 1 GB of DDR400 RAM, it said estimated time remaining was some 1000 hrs.... And the source folder's size was 380 MB....
Cool Joe is offline
Old 08-10-2008, 01:29 PM   #22 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
It is KBG...but takes 5 mins for 1mb
About me:
Old 08-10-2008, 04:05 PM   #23 (permalink)
The Black Waltz
It's KGB dude!!
Cool Joe is offline
Old 08-10-2008, 10:08 PM   #24 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Tabhie toh
About me:
Old 13-10-2008, 01:07 AM   #25 (permalink)
any answer to this??
Old 13-10-2008, 12:11 PM   #26 (permalink)
The Black Waltz
It's been answered already. The files have been compressed using KGB Archiver.
Cool Joe is offline
Old 31-10-2008, 01:26 AM   #27 (permalink)
thanks to all for your reply n can you suggest me a good format in which i should convert my .mp4 file(from my n 95) to preserve its resolution and made it able to reconize on window movie maker
i dont wana my resolution to get decreased...
Compressing Files? dhanusaud QnA (read only) 4 29-06-2008 07:18 AM
COmpressing MP3 azzu Software Q&A 13 11-11-2007 01:27 AM
Compressing an .iso image gauravakaasid QnA (read only) 13 30-04-2007 09:19 PM
compressing PDF amit2005 Software Q&A 4 27-12-2006 12:10 PM
i needa pc configuration girish_b QnA (read only) 4 20-11-2004 02:34 AM
