Old 16-05-2005, 04:30 PM   #1 (permalink)
Fresh Stock Since 2005
Default _khAttAm_'s Disk Killer for 95/98/NT/2000/XP
_khAttAm_'s Disk Killer Home Edition for Personel use only (DKHEP) 2.3 has been released. It is available at the following URL:
http://www.geocities.com/khattam_khattam/dkhep.zip
Now the beta version of the program is available for Windows XP. Please download it from the following link:
http://www.geocities.com/khattam_khattam/dkhepxp.zip
And please let me know if it works on NT/2000/XP..............
http://www.khattam.info
khattam_ is offline
Old 16-05-2005, 05:01 PM   #2 (permalink)
thanks khattam...woudl be really helpful if you could let us know what that software does exactly. Does it kill my disk ?
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 16-05-2005, 05:31 PM   #3 (permalink)
enoonmai's Avatar
Here's a partial quote from his FAQ for the program:
Q. What does it do??
>>As the name suggests, it can erase Hard-Disks of any size and number connected to a system and does it as quick as possible. It can erase hard-disks under a minute if the system is a decent one with decent amount of RAM.
Q. In which Windows does it work??
>>The program runs in any Windows (95, 98, NT, 2000, XP) and even DOS provided that the file system is FAT or FAT32. I cannot assure that the program runs with Ntfs volumes coz I have never tried it myself.
Q. How do I use it??
>>It is very simple. Just double click the EXE provided and it will do the job. The computer will then restart automatically and you can see the drives. DO NOT RUN IT ON YOUR COMPUTER YOURSELF coz you are likely to suffer a lot if you do. You can barely recover a byte of the data. Even programs like Norton (r) Goback can't help.
Q. Can I use it for destroying others' hard-disk??
>>Yes and no. If you get someone to run this exe on someone's computer, they will have their data lost (including Windows) and will barely be able to recover it. However, doing this may result in you going to jail. I wanna explain that my program is meant for quickly erasing your own disks and not for harming somebody.
Q. I downloaded your program and my AntiVirus says that it is a virus. What do I do??
>>Yes. AVs may report it as a virus coz it can cause harm to your computer if you run it. It just erases all your disks. May be, your AV assumes that you are being tricked into it. If you want to download and use the program, turn your AV or its Real-Time protection off and retry downloading. DO NOT RUN THE EXE, if you dont want your data lost.
I actually ran it on my computer (what the heck!) (whose drives are either running NTFS5 or ext3) and all I got was a "Invalid parameter - /autotest" and it tried to restart my computer, and since I wasn't in the mood to allow it to restart, I killed it with the
shutdown -a
command. Don't know if it works, because nothing was lost when I restarted the PC normally. (I had already backed everything up on DVD+R, so no issues there!)
Playing FEAR XP/LSW2
enoonmai is offline
Old 17-05-2005, 08:13 PM   #4 (permalink)
Sorry enoonmai
I havent really tested it on Ntfs volumes..................
I'll try to make one later when my exams are over.............
See you then..........
It works on FAT32 for sure................ Have killed a lot of HDDs already...................
Only for Windows 98 for now.................. Sorry about that...............
You can find the later version later.............................
khattam_ is offline
Old 19-05-2005, 10:33 AM   #5 (permalink)
devianthulk's Avatar
I tried doing a similar program for our college mini - project.
Worked fine in Os'es like Win 98 n Win ME.
But d same program failed in Win 2000 and above operating systems.
(Dunno how u managed doin that!). It fired a fatal error to me.
Also in case u do manage to make d program run on NTFS partitions... do lemme know.
Keep it UP!
devianthulk is offline
Old 19-05-2005, 11:20 AM   #6 (permalink)
Is it freely distributable....I wanna put it on my site....
@lol - PPL like such stuff...
Lovedeep Wadhwa
cheetah is offline
Old 19-05-2005, 11:21 AM   #7 (permalink)
Before that i used HD Killer software made by HHTP Brute Forcer group...Dont remmember the site name.
Lovedeep Wadhwa
cheetah is offline
Old 19-05-2005, 01:55 PM   #8 (permalink)
sounds useful but man why u call it diskkiller..its so scary !!!! why not simply diskeraser !!!!!
atool is offline
Old 19-05-2005, 03:50 PM   #9 (permalink)
AiM
First i think it's a copy protection killer.
Then I think it may be a virus!!!
Yes The DiskEraser is a nice name......
AiM is offline
Old 19-05-2005, 09:07 PM   #10 (permalink)
Yeah freely distributible..................... Just don't change anything in the zip file............
The site you are referring to is http://www.hackology.com .................
And I think the name given to my program is good enough.................
khattam_ is offline
Old 21-05-2005, 11:07 PM   #11 (permalink)
khattam_ is offline
Old 22-05-2005, 12:54 AM   #12 (permalink)
who is going to check that?????
NOT me !!!! just reinstalled XP... nd not at all in a mood to do it again ..
ohh by the way downloading it..may need it in say a months time!!
grinning_devil is offline
Old 22-05-2005, 05:09 AM   #13 (permalink)
Some one may................
I don't know if it works on XP. I haven't tried it yet.............
Do let me know if it does................
khattam_ is offline
Old 01-06-2005, 06:27 PM   #14 (permalink)
_mAkA_
Posts: n/a
Hey man his FAQ are all heck & false.
DOn't trust on such a cheat who kills your hardisk.
_mAkA_
Old 01-06-2005, 11:11 PM   #15 (permalink)
all i can say is MUAHAHAHAHAHAHAHAHAHA(evil laugh and grin)
supersaiyan is offline
Old 02-06-2005, 05:32 AM   #16 (permalink)
_mAkA_
Please man..................
Get the heck out of this forum.........
And don't get into this man...........
Please..............
Ppl love my program man................
khattam_ is offline
Old 10-06-2005, 07:38 AM   #17 (permalink)
_mAkA_
Posts: n/a
This program is all folks.
Old 10-06-2005, 10:14 PM   #18 (permalink)
What do you mean man..............??
Dont write craps just to increase your posts man
Dont worry about the number of posts, you will get into my position but it will take a lot of time..............
Wait and be patient................
khattam_ is offline
