Old 25-09-2008, 08:33 PM   #1 (permalink)
chahal63's Avatar
Lightbulb Help !!! CD/DVD Burning Issue...
Hi Friends,
I have a query regarding burning of CD /DVD. Is there any way to burn CD/DVD with the help of any software or whatever, so that whenever we insert that particular CD/DVD into any PC it should prompt for password? Any trick or method regarding this?
Waiting for your reply.. Thanks in advance.
Your Friend
chahal63 is offline
Old 25-09-2008, 10:16 PM   #2 (permalink)
Core i7 (nehalem) Owner
ashu888ashu888's Avatar
Default Re: Help !!! CD/DVD Burning Issue...
u mean asking password b4 burning the CD/DVD ?? if yes, then i dont think there is any such s/ware around...
But, if u meant tat the s./w shud ask for a password b4 opening the files, then u can winRAR ur files with the password option
Cheers n e-peace...
btw, u can create user accounts wich can restrict the use of CD/DVD burning.. with u being the admin adn let users login into a guest account.
Core i7-920
MSi X58 Pro-E
Corsair 3x1GB
Tagan BZ1100
WD 1TB
22" Samsung 2233SW
APC SUA1500i UPS
Last edited by ashu888ashu888; 25-09-2008 at 10:17 PM. Reason: Automerged Doublepost
ashu888ashu888 is offline
Old 26-09-2008, 02:04 PM   #3 (permalink)
Daydream Believer
Ross's Avatar
Exclamation Re: Help !!! CD/DVD Burning Issue...
Originally Posted by chahal63 View Post
Hi Friends,
Your Friend
Hi, check this out, i am not very sure, but it may help...
http://www.softpedia.com/get/Securit...D-Secure.shtml
Ross is offline
Old 26-09-2008, 09:27 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
There is a thread by Amir.php in tutorials section. Check that.
dheeraj_kumar is offline
Help !!! CD/DVD Burning Issue... chahal63 Software Q&A 3 26-09-2008 06:46 PM
Difference between burning CD/DVD as MP3 Vs burning as DATA CD/DVD in Nero ajayritik Software Q&A 1 06-09-2007 07:33 PM
CD burning issue pradeepbp Hardware Q&A 5 22-05-2006 09:43 AM
DVD burning ISSUE amitava82 QnA (read only) 6 27-12-2005 08:52 PM
burning of 9gb dvd myms QnA (read only) 6 23-09-2005 12:06 AM
