Old 24-09-2008, 08:44 PM   #1 (permalink)
TeCh Blogger : Gtechinfo
gau_pppu's Avatar
Default can a cheep sound card improve sound quality?
I recently bought a creative inspire 4.1 which has two mono input and i had to connect it to the computer with a jack. the sound quality is good but i wnat to know that will it get more enhanced if i connect a 16bit 6.1 channel sound card sound.. ?
i saw a 16 bit 6.1 channel sound card in the store which cost rs 450. will it improve the sound quality if i connect it ? my mother board is Intel D101GGC,
My TeCh Blog: Gtechinfo
>> http://gtechforall.blogspot.com
Mobile Blog : Gtechmobiles
>> http://gtechmobiles.blogspot.com
gau_pppu is offline
Old 25-09-2008, 07:52 PM   #2 (permalink)
gurujee's Avatar
Default Re: can a cheep sound card improve sound quality?
whats ur onboard sound driver ?
i dont think a 16bit ordinary soundcard will improve ur sound quality. Creative sound blaster can do. but if ur onboard sound is high def. realtec sound then i think it is enough for creative 4.1.
gurujee is offline
Old 25-09-2008, 10:49 PM   #3 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Not much of an advantage, spend the money on a software like SRS Audio Enhancer, works awesome, and it's like 500Rs.
About me:
http://about.me/preetam_nath
comp@ddict is offline
Old 25-09-2008, 11:08 PM   #4 (permalink)
dá ûnrêäl Kiñg
zyberboy's Avatar
which mobo do u hav? if its new dont buy the card
My Stomach pains:D:D
http://tinyurl.com/32jj4m
zyberboy is offline
Old 25-09-2008, 11:31 PM   #5 (permalink)
gau_pppu's Avatar
@ Gurujee
when I was using XP i use to install realtek sound driver but now i am using vista for about 6 month where I need not install any sound driver ..
@ Comp@dict
please check this link
http://www.newfreedownloads.com/MP3-...o-Sandbox.html
are U talking about this software...?
@ Zyberboy
i have intel D101GGC mother board which is about 3 year old
gau_pppu is offline
Old 26-09-2008, 12:14 AM   #6 (permalink)
Lets Do It!
amrawtanshx's Avatar
I do use SRS Audio Enhancer and agree with comp@ddict.
But if u want very good sound quality .. U should invest in a sound card.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 26-09-2008, 12:49 PM   #7 (permalink)
EXIT: DATA Junkyard
comp@ddict's Avatar
Yes, if u're an enthusiast then settle for a sound card within 3-5k like
Creative X-Fi HS350 @ 4.5k
Other option for entry level 5.1 super sound is:
Creative Activa 5.1 @ 1k
About me:
Old 26-09-2008, 12:56 PM   #8 (permalink)
gurujee's Avatar
Originally Posted by gau_pppu View Post
@ Gurujee
if 3 years old, u need a sound card for better output from speakers..but since it is creative 4.1, i will suggest just settle for creative audigy 24bit
http://in.creative.com/products/prod...=14189&listby=
gurujee is offline
Improve Sound Quality phanibhushan QnA (read only) 1 08-06-2007 01:36 PM
Hissing Sound/Disturbance Coming From Speakers/Sound Card ! mikeon Audio 8 15-10-2006 10:37 AM
How to Improve the Sound Quality of Nokia 3230? jiteshbhimani Mobiles and Tablets 5 10-11-2005 05:55 PM
