Old 23-09-2008, 07:36 PM   #1 (permalink)
yrana2002's Avatar
Default Ram recognizing error
I got 2GB RAM in my laptop of 160GB hard disk.. The thing ive noticed is, even though i have a 2GB DDR2 Ram module installed, my system only shows 1.75GB
I know that system does reserve some amount of memory.. but ive seen other systems with 2GB ram, where it displays 1.83GB installed
Is there anything wrong with my sytem? Is it ok to increase the RAM available for usage?
Dont ever involve in a dispute with a fool. The viewers might not be able to distinguish between the two :rolleyes:
yrana2002 is offline
Old 23-09-2008, 07:46 PM   #2 (permalink)
gkbhat.blogspot.com
Default Re: Ram recognizing error
Some amount of ram is used for the graphics card.May be the graphics ram is set to 256mb in yours so it is showing 1.75gb. You can increase the amount of ram by decreasing the graphics memory in the bios.
gk2k is offline
Old 23-09-2008, 07:53 PM   #3 (permalink)
Violent serenity.
Psychosocial's Avatar
yus, IGP might have been alloted 256MB RAM and thus its only showing 1.75GB.
Psychosocial is offline
Old 23-09-2008, 11:32 PM   #4 (permalink)
yrana2002's Avatar
Well, i thought so, but i wanted to know whether reducing ram for my graphic would have any difference on my game running capability..
also, is it possible to set higher amount of ram for the graphics?
Old 24-09-2008, 12:06 AM   #5 (permalink)
Violent serenity.
About setting it higher -->> Depends but AFAIK 256MB will be the max . On some laptops and mobos, it can go higher. Check it out in the BIOS.
About lowering it -->> Yus, it will definitely have an impact on your game's performance.
Old 24-09-2008, 12:13 AM   #6 (permalink)
I M A *STAR*
saqib_khan's Avatar
Don't lower RAM for graphics.
Go with ur defaults only.
Blogging at:
Technostarry
saqib_khan is offline
Old 24-09-2008, 04:21 PM   #7 (permalink)
gkbhat.blogspot.com
It would reduce your gaming capabilities for high end games otherwise no problem
gk2k is offline
Old 24-09-2008, 07:42 PM   #8 (permalink)
yrana2002's Avatar
Well, i basically got a Nvidia Geforece go 7000M card, and i found out that it supports 256MB dedicated memory and 648MB shared memory...
So, is there anything to do with the "Shared" part?
Splinter Cell:Double Agent Visual C++ runtime error and ***MUST CHECK*** error zerohourkill Gamerz 17 04-08-2007 02:47 PM
Trouble Recognizing CD/DVD Drive all of a sudden ! arnold Hardware Q&A 2 16-05-2007 11:59 AM
Error error error....gives me hell of a terror abhilash QnA (read only) 4 06-11-2004 12:41 AM
cd not recognizing data .. alib_i QnA (read only) 11 17-08-2004 09:08 PM
