hi i know that this is a avast web protection file....
i read about it in a blog
and diabled it....
but not able to get it back wat should i do>>??????
I don't know the exact path but it's in the root of the folder where you installed Avast! Just search and you'll find it. Run it. Make sure to show hidden files and folders first. Just in case, you know.
Double click on avast icon in taskbar then click details & enable web server or whatever u want
If u disabled it frm services then just make the services automatic & reboot
