Old 22-09-2008, 12:36 PM   #1 (permalink)
Default How to create list of files in a folder?
I often need to create list of files inside a folder, which is a tedious and time taking job
especiall when the no. of files inside a folder is very large. Is there any software free or paid that can do this job for me? Thanx in advance.
Maxfx is offline
Old 22-09-2008, 01:06 PM   #2 (permalink)
Default Re: How to create list of files in a folder?
Go to DOS prompt (enter 'cmd' in run box of Win XP or 'command' in run box of earlier Windows version...
Type 'dir /?' to get an idea of what are the options to get directory listing...
Enter 'dir <parameters> >filename.txt' to get the directory listing output to the required file...
For example, if you want a list of all the files in the directory and all subdirectories, and store it list.txt file, enter 'dir /s >list.txt'
Arun
sakumar79 is offline
Old 22-09-2008, 03:26 PM   #3 (permalink)
"Aal Izz Well"
Krazzy Warrior's Avatar
1. Open Notepad and create a blank file filelist.txt in C:\
2. Open Another Notepad and copy-paste the following data in it.
cd %1
dir /a /b /-p /o:gen >C:\filelist.txt
start notepad C:\filelist.txt
Save the file with name Krazzy Warrior.bat and save it anywhere you wish (in folder whose list u want to create).then open the folder and click on the bat file and u will get ur list created..
http://twitter.com/krazzywarrior
Krazzy Warrior is offline
Old 22-09-2008, 04:15 PM   #4 (permalink)
The Black Waltz
It can be any name you wish and not necessarily Krazzy Warrior.
Good one KW
#krow @ irc.freenode.net
Cool Joe is offline
Old 22-09-2008, 05:17 PM   #5 (permalink)
"Aal Izz Well"
lol
Old 03-10-2008, 12:01 PM   #6 (permalink)
static_x's Avatar
u can use a small utility called Karen directory Printer...very handy and very useful...
static_x is offline
how to create mailing list in gmail? Cool Joe Internet & WWW 1 27-06-2008 02:58 AM
U cannot create a folder name con utsav Technology News 23 02-12-2007 11:28 AM
Create list of all files and folders with a right-click!! shady_inc Tutorials 15 30-11-2007 06:31 AM
Create a list of MS Word Shortcut keys pillainp Tutorials 4 31-07-2007 09:09 AM
Create Folder Tom Thomas Software Q&A 4 23-10-2005 06:26 PM
