Old 16-05-2005, 09:18 AM   #1 (permalink)
MVP in VC++
Default Help needed.....
I have a problem in my system.....firstly i had a asrock motherboard with
intel chipset....It was working fine.....I brought a new intel 865GF motherboard and replaced the old one..I replaced the old 15' monitor with new LG 17' monitor....
Now my problem is.......After formatting the c: drive and when i try to install either the win98se or win xp.... the system hangs indefinetly...
i tried several times.....nothing could be done.....Please help me in this matter....
cvvikram is offline
Old 16-05-2005, 11:36 AM   #2 (permalink)
club_pranay's Avatar
at what stage the setup hangs? hardware detection?
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
club_pranay is offline
Old 16-05-2005, 01:34 PM   #3 (permalink)
MVP in VC++
It hangs at various stages,while copying files, while scanning the drives, during the installatio stage etc...
cvvikram is offline
Old 16-05-2005, 01:44 PM   #4 (permalink)
there might be some sort of lose connection
please check all the cables, ram modules etc.
Old 16-05-2005, 01:50 PM   #5 (permalink)
MVP in VC++
I removed all the conections,pheripherals and inserted it...but still the problem persists....most probably there is problem with the bios or hard disk has crashed....when i had the old motherboard i bought the latest LG 17' monitor it was working fine.....but when i replaced the old motherboard with intel 865GBF motherboard....it worked for 5min and it blacked out with indicator blipping....so i formatted the c: to start from first...
cvvikram is offline
Old 16-05-2005, 03:06 PM   #6 (permalink)
well, this is'nt a HDD problem(u can try using that hdd on a different machine)
get your mobo checked at once!!!
also, provide the complete old and new hardware details.
you can easily verify ram, processor, hdd by trying them on other computer.
