Originally Posted by saurav_cheeta
why not... if he just detach the HDD from the old system & attach it on the new mobo system... then at the time of boot OS will (98 2000, xp) ask or the installation disk (path).... & he just has to install the drivers of the new mobo.... thats it... why i am saying this?? as i have done that....
well bro dono how u managed it..but when u change mobo proccy....its not only these 2 components are chaged but all ur IRQ's , IDE settings, Bridge controllers , memory settings etc , in short every thing at the base changes...so just reinstall of Drivers wont help much....
any ways..Scorpio as u say u have rucial data and some very important software on the hdd..so what u can do is rename he program files folder ..then reinstall OS...after rename the prog files folder again......well tell u what i am not sure about this method....but worth giving a try...
