19-09-2008, 12:04 PM
Need suggestion
Hello all,
I am upgrading my pc. So, I would like to have some suggestions.
I am planning to configure a new system with MC OSX and also windows xp. I am planning to buy Dell 24 inch monitor . Please provide me the best available configuration with graphics card.
Regards,
Soori
19-09-2008, 01:29 PM
The Black Waltz
Re: Need suggestion
Since you're upgrading, why don't you post your current config here? Maybe some of your current components can be put to use. Also mention the budget.
#krow @ irc.freenode.net
19-09-2008, 03:50 PM
Re: Need suggestion
Hey, thanks for the reply.
Well, I would like to retain my old pc as it is. I would like to configure a new pc. Apart from the monitor which have depicted above, would like a better configuration. meanwhile the budget would be at below 40 K excluding the monitor.
19-09-2008, 04:31 PM
AFK
Re: Need suggestion
19-09-2008, 04:43 PM
The Black Waltz
Re: Need suggestion
MSI P35 Neo F + Intel Core 2 Duo E7200 (Rs 10,000)
Sapphire HD4850 (Rs 10,000)
Transcend 2x1 GB DDR2 800 Mhz (Rs 1,800)
These are the core components which you should use. Go for a hard drive from Western Digital. Buy a DVD writer from LG. Buy a cheap keyboard + mouse combo from Logitech.
Wait for other members to post speaker suggestions. You'll also need a cabinet and power supply. Wait for others to post about this.
If the HD4850 doesn't fit your budget, go for an Xpert Vision 9600GT (Rs 5,500).
19-09-2008, 05:00 PM
Excessive happiness
Re: Need suggestion
E8400(7.5k)/E7200(5.5k)+MSI P45 Neo F(5.8k)+2x2GB DDR2(4k)+Palit/Sapphire HD4850(9.8k)+WD Caviar 640GB(3.7k)+Zebby Cabby(1.5k)+Corsair VX450W/CM600W(Both costs same as 3.2k)+Logitech Wireless Combo(1.3k)+Samsung/LG/ASUS DVD RW(1.1k) = 37.9k(If u choose E8400 as ur proccy)/ 35.9k(If u choose E7200).....
Dont settle down anything below HD4850 as its the best VFM card now.....
For Speaker go for Creative A300 Speakers for 1.2k or Altec Lansing one for 1.5k(Better than Creative one)....
If u wanna reduce the budget just go for 2GBRAM(1.8k) instead of 4GB(4k).. U'll save around 2.2k and choose E7200 which reduce another 2k...Total 4.2k....
My First Android phone : Samsung Galaxy SL i9003 - Rooted & Gingerbread XXKPQ
Updated : superteekz_V2 ROM for XXKPQ.
PS Request
19-09-2008, 05:15 PM
Re: Need suggestion
Really great. Thank you very much. Any reviews about the monitor guys?
19-09-2008, 05:18 PM
Excessive happiness
Re: Need suggestion
Don't hesitate to buy that monitor...Just grab that as it's one of the best monitors available now...... I suggest u go for it..... Dell 24"+HD4850 = Gaming rocks.....
PS Request
19-09-2008, 08:43 PM
The Black Waltz
Re: Need suggestion
That's right.
Dell+HD4850= wonderful gaming results. It's a good thing you've not included the monitor's cost in that budget.
@Rajkumar- P35 or P45 Neo F???
Reason: Automerged Doublepost
19-09-2008, 11:06 PM
EXIT: DATA Junkyard
Re: Need suggestion
Yeah, you can browse through more of the procc's an mobo prices here:
Hardware price list/spec sheet
20-09-2008, 10:21 AM
Re: Need suggestion
I have inquired Dell (bangalore) regarding the monitor and got a quotation inclusive off all taxes for Rs 19,288.86 .
20-09-2008, 11:26 AM
Violent serenity.
Re: Need suggestion
Ok as you are going for a high res. monitor, you will need a little more juice to pump it.
See this --
E7200 + MSI P45 Neo-F + 2x2GB Transcend DDR2 800MHz RAM + WD Caviar 640GB HDD + Palit HD4870 + LG H55n optical drive + CM750W PSU + CM Elite 330 cabinet + Logitech Gaming G1 Desktop kbd/mouse + Altec Lansing BXR1121
20-09-2008, 12:43 PM
EXIT: DATA Junkyard
Re: Need suggestion
Instead, go for:
1066MHz OCZ DDR2 RAM @ 4k, will be same priced as 4GB DDR2 800MHz but better performance and 1066MHz is the FSB of E7200, so u'll receive just performance, and also better OCing results.
20-09-2008, 03:55 PM
Excessive happiness
Re: Need suggestion
P45 Neo F..... Is there any pbm?
PS Request
20-09-2008, 03:56 PM
The Black Waltz
Re: Need suggestion
No... Just asked. Didn't know that P45 was available so cheap....
20-09-2008, 03:58 PM
Excessive happiness
Re: Need suggestion
6k -- cheap.  ... Not for me...
PS Request
22-09-2008, 01:22 PM
Re: Need suggestion
Is it illegal to install a MAC OSX in a assembled or custom built pc?
22-09-2008, 02:03 PM
Excessive happiness
Re: Need suggestion
Yes, i think so. Coz Mac OS always come with Mac PC's(Correct me if i wrong) and i dont think we can purchase it like Windows XP...
If so, then sure its illegal
PS Request
22-09-2008, 02:06 PM
#19 (permalink)
Violent serenity.
Re: Need suggestion
No, its not legal.
BTW, why do you want to ruin your newly bought PC
22-09-2008, 02:57 PM
#20 (permalink)
Re: Need suggestion
Originally Posted by KPower Mania
No, its not legal.
You mean it is illegal? However, can anyone shed more light on this ?
22-09-2008, 03:21 PM
#21 (permalink)
Violent serenity.
Re: Need suggestion
Ya, its illegal.
But, it boils down to the same thing....WHY ON THIS DAMN EARTH DO YOU WANT TO RUIN YOUR SYSTEM BY INSTALLING MAX OSX ON IT ?
22-09-2008, 03:38 PM
#22 (permalink)
Excessive happiness
Re: Need suggestion
Ya, its illegal.
Hey kiddo, what do u know about Mac OS.... Did u ever use it?... BTW How u come to tis decision....? Its weird one can take decision w/o even use it....
PS Request
22-09-2008, 03:47 PM
#23 (permalink)
Violent serenity.
Re: Need suggestion
^^Ha!
How do you know if have used it or not ??
Think before you post....Young age dosent mean that I havent experienced anything  .
22-09-2008, 03:52 PM
#24 (permalink)
Excessive happiness
Re: Need suggestion
^^Ha!
OK... If u already used it, then what makes u feel bad with Mac OS....
OK.. Cool kiddo... I just pre-assume myself ...
PS Request
22-09-2008, 03:58 PM
#25 (permalink)
Re: Need suggestion
Have heard lot about MACOS X. It is not like runing the pc. Giving a try in not bad. Just to explore many things.
So shouldn't I buy the MAC OSX and install on the assembled PC. Because, I dont want to spend too much on MAC hardware..
22-09-2008, 04:03 PM
#26 (permalink)
Excessive happiness
Re: Need suggestion
Just do whatever u wish, and since u said giving a try is not bad, i agree that. So let buy it(I wonder if it avail w/o MAC Hardware) and give it a try and let us know how it is..
PS Request
22-09-2008, 04:08 PM
#27 (permalink)
The Black Waltz
Re: Need suggestion
It's obvious isn't it???
He's a gamer and gamers don't go well with Mac OS. It's better to use Vista than Mac OSX. You get all the eye candy and security, and you also get to game on it.
22-09-2008, 04:22 PM
#28 (permalink)
Excessive happiness
Re: Need suggestion
I just forgot that... How i am...
BTW I agree that for gaming Vista is better than Mac OS and now i get the reason y KPowerMania blaming Mac OS....
PS Request
22-09-2008, 04:58 PM
#29 (permalink)
Re: Need suggestion
As far am concerned, am not an extreme gamer. I just think dual boot would do fine if I wish to play games
22-09-2008, 05:04 PM
#30 (permalink)
Excessive happiness
Re: Need suggestion
 .. Go with it man.. NO harm in it..
PS Request
Search this Thread |
