Originally Posted by rohan_shenoy
Did you check your folder and file permissions? Is the joomla15 dir and index file writable by non-privileged users?
I installed with default permissions on the server. I did not have to chmod anything
Did you perform a recent upgrade?
-There could be a fair possibility that at the end of the upgrade process, the file permissions were not changed and left vulnerable to attacks.
No
Do you have the recent version(of main joomla as well as modules) with all security fixes?
Yes
Have you seen if some others using the save version(exactly as yours) have been defaced?
Don't know. See I have three domains on the server, one points to the root of my account, and the other to subfolders containing the data. Curiously, the files in the folder which points to neville.in was not touched, except its feedback form, which is linked to a php file?? It is online right now. May I point out that I had a forum on phpbb which I set up two days back exactly as they have mentioned in their instructions, and a Joomla site which has been around for a month or so.
It could also be a server security issue!(in that case, other sites hosted on the same server as yours are also at risk! so report the mater to your webhost immediately!)
I have, and it's now twelve hours up and no response. In fact I just redirected my address from cpanel as I did not want to disturb anything there.
Also, finding IP is not enough as they use proxies and are masters is cleaning their traces!
Yes you're right
Thank you for your time
