Old 15-05-2005, 04:34 PM   #1 (permalink)
Default jet audio
I have jet audio 6.0.6.4806. I dwnlded some skins in the exe format. But everytime I try opening those skins I get an error saying the file dwnlded maybe corrupt or incomplete. How do I get new skins for jet audio?
gambit is offline
Old 15-05-2005, 05:10 PM   #2 (permalink)
QA Juggler
saROMan's Avatar
well u can get skins from here ...http://www.skinbase.org/section.php?sections=jetaudio
or skins are also available at the Site itself
try using a download manager..eg flashget etc to d/l the complete skin..coz i dnt had any probs d/ling and installing skins ....
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 17-05-2005, 11:29 PM   #3 (permalink)
Hey saroman I dwnldd the skins from the same site but still cldn't install them.
gambit is offline
Old 18-05-2005, 02:58 AM   #4 (permalink)
expertno.1's Avatar
ther may be problem ith the skin selection of jet audio
unistall it
install it
then post
expertno.1 is offline
Old 20-05-2005, 11:35 AM   #5 (permalink)
I get the following error msg when i open the skin which is in exe format:
"Installer corrupted or incomplete- maybe result of failed dwnld or corruption. Try the /NCRC cmd line switch"
gambit is offline
Old 20-05-2005, 01:20 PM   #6 (permalink)
expertno.1's Avatar
the best would be to use internet downlaod manager
or Downlaod accelerator plus (if you like the ads)
Old 20-05-2005, 01:29 PM   #7 (permalink)
Just Do It
Charley's Avatar
It does work here.. Cool ones m8.
Charley is offline
