Old 01-09-2004, 06:34 PM   #1 (permalink)
We Both Have a Mouse!!!
nishantv2003's Avatar
Default STILL CONFUSED???
HEY GUYES I AM STILL CONFUSED SHOULD I BUY AMD ATHLON XP 64 3000+@2.2GHZ OR AMD ATHLON XP 64 3002+ OR INTEL PENTIUM 4 3.06GHZ.
BUT REMEMBER IT SHOULD NOT COST MORE THAN R.S.18000.
nishantv2003 is offline
Old 01-09-2004, 06:37 PM   #2 (permalink)
SORRY IT IS AMD ATHLON XP 64 3200+ NOT 3002+
Old 01-09-2004, 09:09 PM   #3 (permalink)
busyanuj's Avatar
AMD 64 is the best thing for the future, as the 32-bit processors will be phased out in the next two years.
busyanuj is offline
Old 01-09-2004, 09:59 PM   #4 (permalink)
AMD64 3000+
nikhilesh is offline
Old 02-09-2004, 12:06 AM   #5 (permalink)
amd 64
No Mercy, No Limits.
theraven is offline
Old 02-09-2004, 03:00 PM   #6 (permalink)
i was wondering how much will p4 3.2 and amd fx-51 will cost
Old 02-09-2004, 10:21 PM   #7 (permalink)
http://business.vsnl.com/deltapage/price.htm
more or less same prices everywhere
theraven is offline
Old 02-09-2004, 10:55 PM   #8 (permalink)
thanks theraven you helprd me verry much.
i am confused over AMD ATHLON 3000+ OR INTEL P4 3.0HT AND IF I TAKE MY BUDGET A LITTLE MORE HIGHER THEN IT IS BETWEEN AMD FX-51 OR INTEL P4 3.2 HT OR EXTREM EDITION???
Now what do you want to suggest amd or intel.
AND IF I DECIDE ATHLON 3000+ THEN MOTHER BOARD
1.ASUS K8V
2.ASUS K8V DELUX[WHAT IS THE DIFFERENCE BETWEEN BOTH OF THEM]
3.MSI K8T Neo-FIS2R
4.MSI K8N Neo Platinum[WHAT IS THE DIFFERENCE BETWEEN BOTH OF THEM].
THANKS FOR YOUR REPLYS
REGARDS,
NISHANT.
C2D E6750@3.6GHz - XFX 650i Ultra - XFX 8600GT - 2x1 2GB 800MHz JetRam - CoolerMaster eXtreme Power Duo 600W - 750GB HDD - LiteOn LightScribe DVD RW -
HP W1907 19" Wide...
and Altec Lansing ATP3...
Old 03-09-2004, 10:20 AM   #9 (permalink)
amd all the way
mobos i suggest only asus
for details check out asus.com
i cant get thru or i wouldve posted
well there is inbuilt wifi in dlx model i think so thats 1 diff.
theraven is offline
Old 03-09-2004, 01:41 PM   #10 (permalink)
New ASUS K8V-X in the market.
I think it is better than ASUS K8V DELUXE
Old 03-09-2004, 01:48 PM   #11 (permalink)
hey theraven can u give me price list of rashi Peripherals like u give me the prise list of delta peripherals.
i called delta peripherals today they said they do not have fx but they have amd 64 3200+ but they refused to tell me its price,they said come to the shop but that is not possible because i live in Jabalpur[m.p] and delta peripherals r in Chennai.
Old 03-09-2004, 01:54 PM   #12 (permalink)
does intel 3.0ht really make difference in the real world[opening of windows,running of games and application] compared to amd athlon 64 bit 3000+[2.0ghz].
Old 03-09-2004, 06:24 PM   #13 (permalink)
there will be a dlx version in k8v-x also
like i said check the asus site
next these prices differ from place to place
what prices do u want .. there will be ppl ard to help
u need to find a LOCAL DEALER and get the prices from him. ...
the HT hype .. well there are different levels to it ...
no it wont make a difference of the world tho ... but that again is subjective .. depends on the kinda user u are ... for normal users .. it wont make a difference
again i suggest AMD after my recent switch !
theraven is offline
Old 03-09-2004, 06:26 PM   #14 (permalink)
go for the asus K8N-E-deluxe.or the msi K8N neo platinum.they r damn good boards.
Old 05-09-2004, 04:30 PM   #15 (permalink)
i disagree with you NIKHILESH
the AMD's run very good with Nvidia based chipsets
Saint_cyme is offline
Old 05-09-2004, 06:56 PM   #16 (permalink)
Huh?Asus K8N-E dlx and the K8N Neo Platinum are based on Nvidia Chipsets
asky is offline
