Old 15-05-2005, 10:39 AM   #1 (permalink)
Default A porn site as homepage??? (HELP HELP)
Hi guys,
Whenever i login to internet explorer a porn site comes up as a homepage....I have tried to change it by going on tools internet options and change home page but when i restart the PC the poblem persists.
I think we would need to do something in the windows registry but am not really sure abt it.....
Can someone plz help me....
Thanks
Pajakta
prajakta is offline
Old 15-05-2005, 10:47 AM   #2 (permalink)
The CREATURE
zodiac_511's Avatar
It's most likely spyware. So download MS Antispyware,Ad-aware ,Spybot S&D , And Hijack This.Do a scan With all of these. And post the results of the Hijack This scan on the forum. SwatKat will take care of the rest. 8)
..::: ||ZoDiAc|| ::..
zodiac_511 is offline
Old 15-05-2005, 11:09 AM   #3 (permalink)
Tux
Posts: n/a
Whats bad in it...lol
Yeah try the best one
Ad-Aware SE Personal Its best, but update also
Old 15-05-2005, 11:24 AM   #4 (permalink)
use Webroot Spysweeper .The BEST.
Windows XP Pro Service Pack 2 build=2600
Mobo- MSI PM8M-V
GenuineIntel Intel(R) Pentium(R) 4 CPU 2.40GHzRAM : Installed : 512 * 2 MB DDR RAM (TRANSCEND)
XFX FX5200 128 MB
medigit is offline
Old 15-05-2005, 11:36 AM   #5 (permalink)
Download Ad-Aware or spy-sweeper .... & run it!
Also post ur hijackthis log file here!
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
yehmeriidhain is offline
Old 15-05-2005, 11:42 AM   #6 (permalink)
Adawre frm >> http://www.lavasoftusa.com/software/adaware/
Spy bot frm >> http://www.safer-networking.org/en/download/
MS Antispyware >> http://www.microsoft.com/athome/secu...e/default.mspx
do post back after scanning nd cleaning ur system ....
grinning_devil is offline
Old 15-05-2005, 12:53 PM   #7 (permalink)
Use anyone of the above mentioned, all r good but be sure to post ur hijack this log file.
Download Hijack This from here
Shwetanshu Srivastava
shwetanshu is offline
Old 15-05-2005, 03:40 PM   #8 (permalink)
damnthenet's Avatar
MS will come to your rescue forever. You can find the antispyware in the latest DIGIT DVD or at http://www.microsoft.com/athome/secu...e/default.mspx
Scan with it and all your problems'll be solved. Keep the security settings in the software tight so that you can stay away from such problems in the future.
damnthenet is offline
Old 15-05-2005, 03:59 PM   #9 (permalink)
Default MICROSOFT ANTI SPYWARE THE BEST !!
TRY MICROSOFT ANTI SPYWARE !!! ITS TEH BEST AND KEEP IT UPDATED AND KEEP THE OPTION JOIN ANTI SPYWARE COMMUNITY "YES" .
IT WILL HELP BIG TIME . ITS ON THE DIGIT DVD !!!!
King_Niral is offline
Old 15-05-2005, 05:16 PM   #10 (permalink)
QA Juggler
saROMan's Avatar
well i will suggest u use browser Hijack remover ....good tool for this perpose
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 15-05-2005, 08:30 PM   #11 (permalink)
Just Do It
Charley's Avatar
I'd assume that it is only for trial period
Charley is offline
Old 15-05-2005, 08:48 PM   #12 (permalink)
enough solutions...
i would like to add something towards precautions which can help u in future....which doesnt let u go down in future..
ms internet explorer has some loopholes which can be fixed with windows service pack 2 (avl wid digit cds a few months back) ....u can also use firefox browser which is much better in many aspects...gud lucks wid ur fight against pornos
PriyaRanjan Singh
SkyInfoways (P) Ltd.
http://www.skyinfoways.com
crashuniverse is offline
Old 15-05-2005, 10:02 PM   #13 (permalink)
I think having porn is not a problem .. but getting it digged into ur web-browser is a bit tedious .... at times it might be tht U have to use ur system with ur frd's or the worst possible case ur family members ...
Well, there hasn't been ne more replies back from the author .. where r U lost ??
& yeah! dunt forget to post ur hijackthis log file here!
Old 15-05-2005, 11:52 PM   #14 (permalink)
What? Where? How?
escape7's Avatar
u don't know whats bad in it?
98% of the people using internet have started or forwarded "chain mails". If you are one of the 98%, Die a horrible death.
escape7 is offline
Old 16-05-2005, 03:46 AM   #15 (permalink)
Location: The throne at the royal palace of Smiley Kingdom!
I can show you at least 5 reasons why SpubotSD is better than Ad-Aware, "Cydoor" is just one of them. I use Ad-Aware (Pro) +SSD and only SSD detects 3/4 such pests which are not detected by AA.
But this here is a simple case of BHO exploit. So I would suggest Hijack This! scanning and hands-on fixing based on what the log shows.
And MS AntiSpyware also sucks big time - it even says "My Web Search" toolbar is a safe component to install And it will not remain freeware for ever
Calcatian is offline
Old 16-05-2005, 03:49 AM   #16 (permalink)
expertno.1's Avatar
use spybot search and destroy its free and best and included in digit cd and dvd every month
expertno.1 is offline
Old 16-05-2005, 07:25 AM   #17 (permalink)
sidewinder's Avatar
are yaar ssd nd aa se both r free man.Just try out both of them.also they r very small downloads so no worry for dial up user also.
Bombina rocks
sidewinder is offline
Old 16-05-2005, 11:00 AM   #18 (permalink)
Once it happened in my pc. It was due to a chm file, which is a help file format. It was located in c: (parent directory) if it is there remove it and it should work. In internet options in homepage field wat url is provided if u can post it here, it wud be more better to help.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
Old 16-05-2005, 12:28 PM   #19 (permalink)
Just Do It
Charley's Avatar
Be careful next time while you click on pages which show this kind of stuff, they are really bogus and to add to your woes have lots of spyware and trojans in it.
Charley is offline
Old 19-05-2005, 12:53 PM   #20 (permalink)
rohanbee's Avatar
Download MS anti-spyware & do a clean.
Then try spy sweeper as well. They did quite a good job for me....
Hope they will work for you too....
_________________
Quote by Garfield'
rohanbee is offline
Old 19-05-2005, 01:24 PM   #21 (permalink)
Just Do It
Charley's Avatar
Was it a porn link ???? CHM file ...........
Charley is offline
Old 19-05-2005, 02:55 PM   #22 (permalink)
enough talks for a simple prob. dont u ppl think so?
where is moderator to lock the forum. hey prajakta, arent'u confused reading 50+ solutions for a simple prob.
PriyaRanjan Singh
Old 20-05-2005, 10:45 AM   #23 (permalink)
Ya dis is very irritating problem. Use MS Antispyware to avoid such.
PM me if you have any difficulties regarding your Symbian OS cellphone.
suhasingale is offline
Old 20-05-2005, 03:20 PM   #24 (permalink)
I was looking for a cr*ck (word which should not be named here) in some sites one of those loaded that chm file in my pc which had the images, html file embedded in it. So, after manual removal it got ok.
Old 21-05-2005, 12:05 PM   #25 (permalink)
Just Do It
Charley's Avatar
@thecyclone - Good 4 u...
Charley is offline
Old 21-05-2005, 12:34 PM   #26 (permalink)
Tux Fan
shaunak's Avatar
it must b a real embarasing situation to open ie and b greated with u know wat
i had a similar problem some time ago. whernver i tried to go to any site i would b redirected to a stupid french that i had clicked accidently while trying to close a popup. i started using spybot sd and its kept me outta trouble so far
Cheers
Shaunak
Feel free to PM/email me.
shaunak is offline
Old 21-05-2005, 05:59 PM   #27 (permalink)
Calcatian: "MS AntiSpyware says "My Web Search" toolbar is a safe component to install ."
MS AntiSpyware HAH
But it is still under development and i dont think its has crossed its beta stage.
And talking bout security services from microsoft.
In IE the content adviser or blocker..tool when
enabled blocks everything that is hot and the comedy is that it blocks their very own website 'Hotmail.com' as adult content and unsuitable for viewing.
HAH
Thats security for MS.
Spybot S&D is # 1.
But being freeware their definations update service
is not upto the mark.
Try System Mechanic ver 5.
It has a spyware removal feature which is quite reliable if not the best.
But the plus point is that its very fast and can be updated from the iolo site with a singleclick.
Also when it is memory resident its not very resource hungry.
Check it out U ll love it.
amitsaudy is offline
