Old 15-09-2008, 12:12 PM   #1 (permalink)
ajayritik's Avatar
Default How to clean my PC?
I know this may sound as a weird question but I just wanted to check with you all about how to clean my PC. The keyboard, Cabinet, Monitor, Mouse and other things. I have never cleaned the Cabinet except for wiping it using a cloth . I read somewhere that we can use a blower to clean the Cabinet. Will using the air blower harm the motherboard, RAM etc. One more thing I observed was my Microsoft keyboard that I purchased one year back doesnt have the keys as soft as it was when I purchased it. Is there something that I can do to fix this problem?
ajayritik is offline
Old 15-09-2008, 01:56 PM   #2 (permalink)
15.0 GHz
VarDOS's Avatar
Default Re: How to clean my PC?
Visit This : A Guide To Cleaning Ur PC Inside-Out
__________________________________________________ _____
My Blog : http://askvarad.blogspot.com
VarDOS is offline
Old 15-09-2008, 02:38 PM   #3 (permalink)
Troubleshooter
u could use CCleaner 2.0 and above
deepakchan is offline
Old 15-09-2008, 03:21 PM   #4 (permalink)
Democracy is a myth
rhitwick's Avatar
CCleaner??
WTH?
"My opinions may have changed, but not the fact that I am right."
"I'm never wrong. Once I thought I was wrong, but I was wrong"
rhitwick is offline
Old 15-09-2008, 06:46 PM   #5 (permalink)
dreamsalive's Avatar
man hes askin to clean hardwares.
Linux doesn't need no viruses. The users **** up the system by themselves.
dreamsalive is offline
Old 15-09-2008, 08:45 PM   #6 (permalink)
mihirpradhan2004's Avatar
wipe the outer side of the cabinet with a dry cloth. do not use a wet cloth as it may damage some parts like dvd writer. use a big brush to clean the inside of the cabinet. use the brush gently to clean the motherboard and some of the other parts. make sure the connections inside the cabinet do not get loose. for the keyboard, make it upside down and gently tap it for the dust to fall out of it. if it doesn't help, use a small needle to clean the dust in-between the keys. if this too doesn't help, u will have to remove each of the keys of the keyboard one by one using a thing like a screwdriver- then clean the keyboard and place the keys back in. but if you do this, u first have to remember where which key is - a better way is to click a few photographs of the keyboard before removing the keys.
mihirpradhan2004 is offline
Old 15-09-2008, 08:49 PM   #7 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You can use a blower as long as it doesnt blow hot air.
As for your keyboard, take it apart and clean it, put it back carefully. You might waste a few keyboards on the first tries but you'll get good at it, good enough to take apart any KB, clean it and put it back to working condition.
If you cant, pry apart all keys using a screwdriver and clean that place atleast.
dheeraj_kumar is offline
Old 15-09-2008, 10:24 PM   #8 (permalink)
ajayritik's Avatar
Dude looks like you read the title and just replied blindly without checking the body of the thread!
Dude I feel not so comfortable taking apart all the keys from the keyboard. Are you sure I'm not going to damage any of the keys in the process. And what do you mean by telling that I will waste a few keyboards on the first tries. You want me to purchase a new keyboard every time I clean it?
Old 15-09-2008, 11:23 PM   #9 (permalink)
Democracy is a myth
rhitwick's Avatar
I used to clean keyboards like that............but mine is TVS Gold.........each key can be separated......no idea about ur kbd....if its possible like dheraj says, do it, no probs just do remember toput it back properly
rhitwick is offline
Old 15-09-2008, 11:42 PM   #10 (permalink)
Violent serenity.
Psychosocial's Avatar
ya, thats my tut on cleaning your PC, refer to it .
Psychosocial is offline
Old 16-09-2008, 09:04 AM   #11 (permalink)
Hey, what about static? I've heard you got to wear some static belt on the wrist or something before you touch the computer's inner parts.
I opened my CPU, because the processor fan speed has increased - it keeps going up and coming down like its under heavy load even though there is no software running (apart from the usual ones, whose usage I can see in Task Manager). I can see a lot dust on it, but I don't know how to remove the dust, apart from dusting it a bit. Maybe removing the fan and then cleaning it would be better, but I tried pulling it, and it won't come out, there are no clamps that I can see, and I'm afraid I'll break it. The motherboard is D102GGC2, processor is P 4 3.0 Ghz.
HydraHeaded is offline
Old 16-09-2008, 06:46 PM   #12 (permalink)
You can take them apart by a screwdriver - that wont cause any damages at all, assuming you take a photo of the keyboard to make sure which key goes where.
Only if you open it fully(unscrew and all) you have to put it back carefully, making sure the transparent circuit plates align inside. I wasted 2 KBs a loooong time ago since I couldnt put them properly, but kept them for future use. Then I became expert in cleaning keyboard, and fixed both the old KBs Now they work purrfectly.
Old 17-09-2008, 02:54 PM   #13 (permalink)
Troubleshooter
Originally Posted by rhitwick View Post
CCleaner??
WTH?
Sorry. I did not read the body of the post.
D'oh!
Old 17-09-2008, 05:26 PM   #14 (permalink)
a_g = JPKN
s18000rpm's Avatar
for keyboard - get brush (available at almost all PC peripheral shops)
for cabinet - you can use vaccum cleaner, just keep it a bit far & DONT FORGEt to hold/tape the fans when using Vaccum Cleaner.
ASUS K53SV SX520D + BF3
s18000rpm is offline
Old 19-09-2008, 07:11 PM   #15 (permalink)
AFK
thewisecrab's Avatar
http://www.helpwithpcs.com/maintenan...g-keyboard.htm
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 19-09-2008, 08:39 PM   #16 (permalink)
The Black Waltz
Visit http://www.bleepingcomputer.com/tuto...torial118.html
This is a must read tutorial. It's easy to understand, and there's no need to worry about anything, because everything is explained. There are images as well, so the reading isn't boring.
#krow @ irc.freenode.net
Cool Joe is offline
Old 19-09-2008, 10:47 PM   #17 (permalink)
AFK
Thanks for the link beta testing
Got the dust out of hard-to-reach spots too after reading that
Old 20-09-2008, 02:36 PM   #18 (permalink)
The Black Waltz
You're welcome. I reached this site after a Google search, so thanks to Google for that.
Cool Joe is offline
how to clean LCD monitor sohin TVs / Monitors 1 22-09-2007 10:53 AM
Desktop clean Pradeep Kumar KD Software Q&A 2 04-09-2007 07:50 PM
how to clean Interior of pc mkmkmk QnA (read only) 6 11-11-2006 10:32 AM
Clean sweep william QnA (read only) 1 16-07-2006 09:50 AM
How do I clean a CD bharat_r QnA (read only) 4 16-05-2005 02:45 PM
