Old 12-09-2008, 09:21 PM   #1 (permalink)
Right man in wrong place!
cyborg47's Avatar
Default hdd casing doubt...
i want to use my old HDD with USB...i heard that i can be cased.....but my hdd is IDE type...can IDE HDD cased??
Quad Core Q9300, Gigabyte EP45usb3 mobo, Zotac GTX 460 1024MB, 3x2 GB ddr3 memory, cooler master extreme 600W.
...They call me Prophet... - C2:twisted:
cyborg47 is online now
Old 15-09-2008, 10:58 AM   #2 (permalink)
The Frozen Nova
casanova's Avatar
Default Re: hdd casing doubt...
Yes, you can case it. You can get a local IDD casing starting at around 300 bucks. But try to get a branded casing if possible.
www.nerdweed.blogspot.com
casanova is offline
Old 15-09-2008, 12:06 PM   #3 (permalink)
Cool G5's Avatar
Yeah it's possible.
But remember it won't be rugged as external drives. If you plan to transport it, do it safely.
Cool G5 is offline
Old 15-09-2008, 01:14 PM   #4 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
dont use external casing ..... they kill ur hdd ........
... W H O T ...
ax3 is offline
Old 15-09-2008, 02:34 PM   #5 (permalink)
cyborg47's Avatar
An OS has to be installed on the HDD to use it...???
Old 16-09-2008, 11:40 AM   #6 (permalink)
Cool G5's Avatar
Post Re: hdd casing doubt...
No. It will be detected as a removable drive in windows just like your pendrive.
Cool G5 is offline
harddisk casing ritish Hardware Q&A 1 13-02-2008 12:59 PM
3.5" HDD casing crs_cwiz Hardware Q&A 3 25-01-2008 12:39 PM
HDD Casing for an SATA2 HDD abhinav_bipnesh Hardware Q&A 21 12-09-2007 05:28 PM
Ext HDD 2.5'' + casing --- which is the Best Buy? dareprasanna Hardware Q&A 12 06-06-2007 10:42 PM
Where to find this casing ? AshishSharma Hardware Q&A 4 15-05-2007 12:25 PM
