Old 10-09-2008, 07:05 AM   #1 (permalink)
rajat22's Avatar
Wink Is it safe to relocate program files?
My C drive is almost full. I want to relocate files to other drives using programs like 'Application mover'. Is it safe to relocate program files to other drives?
If no , what to do?!!
Thanks in advance.
____________________________________________
A person who never made a mistake never tried anything new.
rajat22 is offline
Old 10-09-2008, 07:33 AM   #2 (permalink)
Default Re: Is it safe to relocate program files?
things may break, use the program which is totally MS certified .
Faun is offline
Old 10-09-2008, 05:13 PM   #3 (permalink)
Not fully safe. Remove softwares and reinstall on other drive.
ThinkFree is offline
Old 10-09-2008, 06:58 PM   #4 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
Format your C and install only the stuff you need. If you cant, be brutal with the shift delete.
dheeraj_kumar is offline
Old 10-09-2008, 08:52 PM   #5 (permalink)
The Black Waltz
You don't need any software to do this. Just moving the folder to another partition works fine for me. Then, you just have to change the target of the shortcut.
#krow @ irc.freenode.net
Cool Joe is offline
Old 10-09-2008, 08:58 PM   #6 (permalink)
^^You will have to change all the locations in the registry as well.
Old 10-09-2008, 09:08 PM   #7 (permalink)
The Black Waltz
^^Yeah, but not in all cases.
I successfully shifted the location of CS without making any registry changes.
Even then, it's quite easy. Just search the registry for any entries made regarding the particular program, and change all the locations to the new one.
Cool Joe is offline
Old 10-09-2008, 09:31 PM   #8 (permalink)
AFK
thewisecrab's Avatar
I'd suggest uninstall and then re-install in another partition
Dont use any software as it might screw up your files.
@beta testing
A few apps can be Ctrl-C ed to other drives without any effect on registry,not all apps
Follow me on http://twitter.com/thewisecrab
"This Jen, is the internet"
thewisecrab is offline
Old 10-09-2008, 09:49 PM   #9 (permalink)
yup some apps are deeply seated into registry, may screw the things.
Faun is offline
Old 10-09-2008, 10:41 PM   #10 (permalink)
CS doesnt depend much on the registry. The only apps that depend a lot on registry are some games. Their protection schemes are dependant on the correct path and are usually encrypted in the registry. Take Bioshock for an example.
Old 11-09-2008, 07:58 PM   #11 (permalink)
The Black Waltz
^^Yeah right. Not all, but some.
@thewisecrab- Ctrl Cing to another partition is not what we want to do, it's Ctrl X and then Ctrl Ving that we want to do
Cool Joe is offline
Old 11-09-2008, 08:25 PM   #12 (permalink)
AFK
same point implied
Anyway, uninstalling and then reinstalling is the best bet IMO
Old 11-09-2008, 09:36 PM   #13 (permalink)
The Black Waltz
If you are uninstalling the program and then installing again, remember to keep the settings. I.e, don't uninstall the user settings as well.
Cool Joe is offline
Old 11-09-2008, 10:03 PM   #14 (permalink)
a_k_s_h_a_y's Avatar
haha lol
i thought you were actually really talking about the program relocation in OS architecture.
Sony Ericsson Flashing, Modding, Patching, Hacking And More !
http://www.akshayy.com/sonyericsson/
a_k_s_h_a_y is offline
relocate the pagefile.sys? rajat22 QnA (read only) 4 21-12-2007 10:48 PM
Cant delete 3 image files even in safe mode ranjan2001 Software Q&A 25 24-08-2007 08:55 PM
can i delete c\program files\Intel ? anandk CPU / Motherboards 3 23-05-2005 09:35 PM
Is it Safe to delete Service Pack Files? lywyre QnA (read only) 4 21-04-2005 05:26 PM
Moving Program Files anishcool QnA (read only) 3 24-09-2004 06:13 PM
