guys is there any s/w using which i can add all .swf files and make it as a movie? and view it.. there are about 80 .swf files that i need to add into as a single movie type file.. id prefer freeware..
There is one software called swish max which i have used as a trialware. It is not free so u have to check if u can import ur swf files and export them as avi. It supports converting your flash movies to avi. Check for the file on download.com
A program is a device used to convert data into error messages.
