Re: Problem With Pen Drive
Could the files be hidden by accident?
Try to unhide all folders and then check.
Are you sure that yours is a genuine Kingston drive? There are many cheap imitations of popular USB drives. Especially the chinese ones. These drives are cheap but not reliable.
If yours really is a branded Kingston drive, then you can get a replacement if your drive is damaged.
#krow @ irc.freenode.net
