Old 14-05-2005, 05:00 PM   #1 (permalink)
KoRn's Avatar
Default BUYING A NEW PC
hey guys i am planning to buy another cpu with the following configs
p4 2.80Ghz
512mbram/256mb ram
80gb hdd/40gb
geforce xfx5200,128mb
thats it.HOW MUCH WILL IT COST??!!please give me the price i am going to buy a branded computer but i am going to tell the engineer wat to put in the configs according to MY WISHie wateva i mentioned above.please tell me the price of another pc the configs r after the slash in the previous configs.
KoRn is offline
Old 14-05-2005, 05:27 PM   #2 (permalink)
Default Re: BUYING A NEW PC
Since you want a branded PC, it is not possible to guess the price of the config. Is the PC for gaming or general usage? What is your budget?
Some suggestions..
First of all, don't go for Pentium. Buy Athlon64 for gaming or Sempron for general usage. FX5200 is too high end for general usage and too weak for gaming. Either use an integrated solution if you're not into gaming or buy a better graphics card if you are.
drvarunmehta is offline
Old 14-05-2005, 06:39 PM   #3 (permalink)
why need title?
bharathbala2003's Avatar
i agree with varun.. if its for gaming pls go in for AMD athlon 64 based.. about the gfx card try gettin sumthin like fx 5500 or atleast 5700(non LE) for better gaming... and go in for 512 MB DDR300
bharathbala2003 is offline
- by gohan89
