Old 14-05-2005, 02:55 PM   #1 (permalink)
mekalodu
iinfi's Avatar
Default whats going where ???
in winXP pro
is there any software which can read what content is being sent and received by each port in the system??
Firewalls like zone alarm allow u to see a max. of 999 log entries .....
but i want the content which is being transferred to be logged ....
is it possible ....
mekalodu
iinfi is offline
Old 15-05-2005, 04:41 PM   #2 (permalink)
mekalodu
iinfi's Avatar
some one told me its possible in Unix/Linux ... but i dunno how ....
i wanna know abt windows
mekalodu
iinfi is offline
Old 15-05-2005, 04:48 PM   #3 (permalink)
QA Juggler
saROMan's Avatar
well there is 1 soft Port explorer thru which u can do all works regarding Ports ..herez the info i got.....
Port Explorer
Allows you to see all the open ports on your system and what programs own them (called Port to Process mapping). Along with this ability it also has many tools including a packet sniffer, bandwidth throttling and country detection to name just a few. Port Explorer has an intuitive GUI that allows you to quickly see all the network activity your computer is involved in, and thanks to its ease of use is allowing people everywhere to do advanced network activities.
We believe Port Explorer is the leading program of its kind, and this independent review by Roger A. Grimes (author of Malicious Mobile Code: Virus Protection for Windows) came to the same conclusion after he compared 11 of the best port-to-process mappers available.
Features:
Finds ALL open and active TCP and UDP ports on your system.
Packet Sniffing allows you to see what data applications are sending over the internet.
Country Detection shows what countries all the IP's on your system are from.
Bandwidth throttling allows you to restrict how much data a program or socket can receive or send.
Trojan Detection built in allowing you to quickly see any possible trojans.
Block or close open ports and processes on your system.
Six BONUS network utilities, including improved Ping, Resolve and Whois clients.
Easy to use graphical interface, totally configurable, no more fumbling around.
Low CPU, MEMORY and RESOURCE usage.
Designed for 32-bit Mcft® Windows™
100% compatible with Windows 95, 98, 98 SE, ME, NT4, 2000, XP, 2003.
Port Explorer is the only port-to-process mapper for Windows 95/98!
Info : http://www.diamondcs.com.au/portexplorer/
8-) सारोमान :!: :!: :!:
saROMan is offline
Old 16-05-2005, 12:43 AM   #4 (permalink)
mekalodu
iinfi's Avatar
thanks for da info ...
mekalodu
iinfi is offline
