Old 01-09-2004, 12:07 PM   #1 (permalink)
atul
Posts: n/a
Default uninstalled
i use w2k ...
i had uninstalled a trial version software ... bt due 2 its limited use i uninstalled it ....
2 use it fully ... i bought it ... & installed it ....
bt the registered version refuses 2 start as it detects the trial version ... which had expired ...
i had uninstalled it (trial) properly ... & even registry entries ver deleted ...
eventhough ... problem persists ....
R there any files which r present in my OS ??? how do i remove them ???
help me out ...
Old 01-09-2004, 12:46 PM   #2 (permalink)
Ethan_Hunt's Avatar
try installing the old one and search for a place where u can insert a cd key or registration key and insert it from the new and original copy u have purchased.if this dosent help Private message me with the softwares desciption and version and the problem and will try to help ya out.peace.
Ethan_Hunt is offline
Old 02-09-2004, 12:20 AM   #3 (permalink)
manishjha18's Avatar
hey dude download add & remove plus 2004 and then unistall
http://drmanishjha.wordpress.com/
manishjha18 is offline
Old 02-09-2004, 11:45 AM   #4 (permalink)
atul
Posts: n/a
nahi yaar ... the trial version was old 1 ... tried keying in the serial no. of new 1 which i bought ...
bt it doesn`t accept it ...
i don`t wanna reinstall w2k only 4 this software ...
Old 02-09-2004, 05:42 PM   #5 (permalink)
King of my own Castle
freshseasons's Avatar
Dont bother with such softwares....i mean some one as good as a genuine user like u who has brought a legal software is having this much trouble ..the company deserves to go bankrupt....
freshseasons is offline
Old 02-09-2004, 09:40 PM   #6 (permalink)
Davislav Ivanuiz!!!
Kl@w-24's Avatar
Did th program's uninstaller remove th registry entries or did u remove them manually ? If th entries were removed by th uninstaller, then u need to search for th prog's entries in th registry and remove them. Also, try searching for ini files related to that program and remove them too.
I was here when the forum's swear filter kept bleeping out the word 'FUNK'. :crazy::censored::eeksign:
www.abhi247.com | The Photohblog A Little Lunacy! [v3]
Flickr!
Kl@w-24 is offline
Old 02-09-2004, 09:49 PM   #7 (permalink)
The problem is that there was some key entry in the registry ... get this software called Registry Monitor and find out where the key is written ..first u might need to install the older version... delete the key and try to install the software and regsiter it.. see the difference!
Knowledge is power!
curvenger is offline
Old 03-09-2004, 12:04 PM   #8 (permalink)
atul
Posts: n/a
thanx ...
will search 4 ini files ... related 2 that software ...
bt i have also manually removed those registry entries related 2 that software ...
