Old 07-09-2008, 01:44 AM   #1 (permalink)
Banned to Spam
Krazy Bluez's Avatar
Location: Look below...not under pants dumbo...use a GPS
Unhappy "Broad"Band problem
Hi guys, I have a BSNL 500 Combo plan, recently I re-installed XP cause due to some heavy tweaking done to my computer by myself which made it unstable and I was myself unable to fix it...lol, anyways my problem is
1> At first I had to connect through the internet through the Dialing method, i.e. by giving the user name and password, but now-a-days it connects all by itself even without giving the user name & password
2> In the modem the green data light is glowing now-a-days which was not happening earlier, can anyone tell me why it's glowing now ???
3> And finally, although I can connect to the internet and surf normally, my uTorrent works and I connects through peers and seeders and downloads data also but Free Download manager is not downloading the data ? I think this is because there is no dial-up connection, right ?
Sorry for whole lotta questions but I hope you will help me out...
My DeviantART page now exists !!!
Krazy-Bluez.deviantart.com
Twitter: http://twitter.com/KrazyBluez
Krazy Bluez is offline
Old 07-09-2008, 02:20 AM   #2 (permalink)
God of Mistakes...
Garbage's Avatar
Default Re: "Broad"Band problem
It seems that you have enabled / made a PPPoE connection of modem.
And if it's the case, then your download manager should work.
Registered Linux User #468778
http://twitter.com/_Garbage_
Garbage is offline
Old 07-09-2008, 03:57 AM   #3 (permalink)
Lets Do It!
amrawtanshx's Avatar
1.Your connection has been changed from Pure Bridged to PPP.So it will connect automatically.
2.You are talking about ACT ... ??? Glowing or Blinking ???
3.It should work.Try reinstalling Download Manager.
"Now you're looking for the secret... but you won't find it, because you don't really want to know. You want to be fooled."
amrawtanshx is offline
Old 07-09-2008, 03:59 AM   #4 (permalink)
œ∑´®†¥¨ˆøπåß∂ƒ©˙∆˚¬Ω≈ ç√∫˜
the.kaushik's Avatar
are you talking about broad band or dial up.. 500 Combo plan is broad band plan and then how are you using modem.. as they gives router not modem.. am confused!
If DAP is not working try FDM.. also tell us from which site are you trying to download
Blogging @ http://classictutorials.com
the.kaushik is offline
Old 07-09-2008, 08:54 AM   #5 (permalink)
Banned to Spam
It's broadband plan, and I don't know what's the difference between router and modem, I checked the box and it was written as modem. (It works as High speed LAN Connection)
How can I tell you here from where I am downloading....
I've tried Softpedia and it gives the same error....
How can I change it back ???
What's ACT ? I meant the DATA light, It is blinking when some data is transmitted and glows when it's idle
Okay, I would try it
Old 07-09-2008, 12:39 PM   #6 (permalink)
Try reinstalling DAP.. if it wont work just try the FDM.. let us know if it works
Old 07-09-2008, 06:45 PM   #7 (permalink)
Lets Do It!
Open 192.168.1.1
Username ... admin & Password ... admin
Go to WAN settings
In WAN type click on PPP.
Enter your username and password.
Click Apply.
The modem I have with my H500 ... Has the ACT light .. To the left of it is Link & to the right of it is LAN.
Old 07-09-2008, 09:47 PM   #8 (permalink)
User Name's Avatar
hey my torrent ares is not connecting with server.It only shows connecting.....
and never connects?
while utorrent is working fine.
User Name is offline
Old 07-09-2008, 10:01 PM   #9 (permalink)
and never connects?
means? i suppose u should download your torrent using utorrent.. give some more details
Old 07-09-2008, 10:15 PM   #10 (permalink)
a_g = JPKN
s18000rpm's Avatar
and never connects?
on my bsnl bb connction, i face similar problem.
LimeWire doesnt connect at all, but FrostWire connects & d/ls at 60+ KBps.
tried all the stuff to connect LimeWire (like proxy....), but it never worked.
ASUS K53SV SX520D + BF3
s18000rpm is online now
Old 07-09-2008, 10:39 PM   #11 (permalink)
Dude the reason is the router blocks the port.. here is a solution and you should be able to figure out how to make it work.
Go to the following site: http://www.portforward.com/english/r...outerindex.htm
Select your router model.. Bsnl uses UTStarcom routers.. select your router under UTStarcom routers and click to go to next page.. now select your application which is getting blocked.. in your case Limeware.. click on limeware.. you will be directed to a page will details.. hope you make it work..
Old 08-09-2008, 12:35 AM   #12 (permalink)
Hi all .. i get BSNL connection 2 days back only..but its server block some important sites....like nseindia.com and my trading Portal.. although i can open home page of my trading portal but not able to login...when click on login page it tries to connect and then die....i have tried following things to get this done..
1. Changed DNS server setting..changed to open DNS....... nothing happened.
2.disabled firewall from router..no gain.
now i think my PC have some serious virus which blocks IP address of the abv sites..so going for hard drive format....
i tried this site whose link is given abv..after selecting Billion router( i have billion 5200S router)..i don't know wht to do to go to nseindia.com
Help me plz
Chintan
chintan786 is offline
Old 08-09-2008, 12:38 AM   #13 (permalink)
a_g = JPKN
s18000rpm's Avatar
will try it out. thanks
Old 08-09-2008, 08:44 AM   #14 (permalink)
Help me plz
Chintan
dude just try this.. go to hidemyass.com and then try to open the site you want and check if you are able to open.. if it opens then there is problem with bsnl.. which city are you using bsnl? same thing happened to me for feedburner.com.. one nice day the site got blocked.. i called up those craps and told my problem and they told they will call me back.. after 2 days they called me back and said that there is problem from there side and it will be fix in 2 days and it was fixed in two days..
Old 08-09-2008, 09:49 AM   #15 (permalink)
thanks kaushik... i am from Ahmedabad..will definetly call today to theses craps..
BSNL SUCKS
Old 08-09-2008, 07:38 PM   #16 (permalink)
BSNL SUCKS
Ya thats true.. but only in help and support because there service is really good compared to other ISP.. if you have used any other ISP you will know it for sure..
Old 08-09-2008, 08:05 PM   #17 (permalink)
Lets Do It!
Still its better cause its more VFM
Old 08-09-2008, 09:40 PM   #18 (permalink)
sagar_jxd's Avatar
tht green light glows only whn the modem is connected with the comp and tht local area connection 100mbps comes means when connection of modem with comp if it is connected thn only it glows
and if u want u don't want to connect ur net auto.
follow these steps
1 go to control panel click on network connection.
2 then click next then on the left hand side u will see first option named"create a new connection"click on it.
3 thn click on next then select connect to the internet n click next
4 thn select"setup my connection manually" click next
4 thn select"connect using a broadband that requires a username and password" click on next n fill up the info it will be created
and ha data light glows never it must hve some problem whenever it glow ur net is nt connected
Looking for PR submission service hire me........
sagar_jxd is offline
Old 09-09-2008, 12:02 AM   #19 (permalink)
I never used any user name and password.. i formatted my comp so many times.. am i missing something?
Old 09-09-2008, 01:07 AM   #20 (permalink)
I have tataVSNL connection from last 3 years....in Aug...it was off for almost 10 days....due tht reason i get BSNL ......tata have some issues..but they take compalints ..work on them..give u feedback...where as BSNL..they act like as if doing Mercy...
BSNL SUCKS......i think now i have to have this connection for 3 months....bullshit....i can stop this also..
Old 09-09-2008, 01:13 PM   #21 (permalink)
Lets Do It!
No.
Your connection is in the PPP mode.
So it automatically connects.
Old 09-09-2008, 03:05 PM   #22 (permalink)
so is there any security issue? I still now dont have any userid and password also the portal id and password never works..(Complaned still resolving )
Old 12-09-2008, 03:16 AM   #23 (permalink)
Banned to Spam
Okay, I've tried re-installing FDM, but the problem persists, actually I can see in the log window that it is saying can't connect to server, so how can I make it now ???
problem in "view" of "folder options" mind021 QnA (read only) 5 23-01-2008 01:43 PM
Broad Band Problem Kaushal Hiwarkar Software Q&A 8 25-08-2007 03:41 PM
VISTA TUTORIAL: Add "Hide File Names" Option in "View" Menu of Folders Vishal Gupta Tutorials 7 27-06-2007 10:46 PM
Bsnl Broad band problem rohanbee Software Q&A 13 15-11-2006 05:25 PM
Broad band speed problem?? Charley QnA (read only) 22 02-03-2005 05:08 PM
