Old 06-09-2008, 01:04 AM   #1 (permalink)
Wise Old Mouse
mrintech's Avatar
Arrow Is it Possible to switch Host without changing domain?
Well friends, I wanna ask you that is it possible to switch hosting service without changing the domain name?
I think switching hosts don't effect any sort of Alexa/Google Rank of the Domain
Pls correct if I am wrong
mrintech is offline
Old 06-09-2008, 03:06 AM   #2 (permalink)
The Devil's Advocate
iMav's Avatar
Default Re: Is it Possible to switch Host without changing domain?
Your main question, yes it si possible to change host w/o changing domain name. For the ranks part, it shouldn't. I only had a bit of google search issues due to mis-configured robots.txt and sitemaps.
http://beingmanan.com
iMav is offline
Old 06-09-2008, 03:48 AM   #3 (permalink)
Wise Old Mouse
mrintech's Avatar
so your issues are solved Now?
I am getting a whole lot of errors in google
mrintech is offline
Old 06-09-2008, 07:35 AM   #4 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
Yes, you change change Hosts without changing the domains. AFAIK i know it should not affect Ranking
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 06-09-2008, 09:46 AM   #5 (permalink)
Elevating Humanity
The Conqueror's Avatar
Yes, You can switch host without changing domain. All you have to do is change your nameservers to your New Host
Regards,
The Conqueror
The Conqueror is online now
Old 06-09-2008, 10:50 AM   #6 (permalink)
iMav's Avatar
Yeah, while changing host, apparently the permissions on the files got fudged. But, now everything is fine.
What errors on Google?
iMav is offline
Old 06-09-2008, 11:36 AM   #7 (permalink)
shashank4u's Avatar
1) yes it is possible
2) No it doesn't have any effect on ranking in 99% of cases.
Be like a postage stamp-stick to one thing until you get there.
shashank4u is offline
Old 06-09-2008, 02:01 PM   #8 (permalink)
Wise Old Mouse
mrintech's Avatar
Following errors I am getting:
The problem is that all was fine 3 days ago (when I setup my website in freehostia), my pages were in google too, but suddenly I got the above shown errors.
I don't know what to do? Help me
I repeat everything was fine and I am following all the guidelines. I also verified my site by uploading HTML file to the host. I also made sitemap.xml and sitemap.xml.gz.
This sudden error made me perplexed as I don't know whats the problem? All was fine but Now it's giving errors. My domain is under www.co.cc
mrintech is offline
Old 06-09-2008, 02:31 PM   #9 (permalink)
iMav's Avatar
Welcome to the club. I faced the same problem. I don't really have stepped tutorial on how I got rid of it. But, do one thing, create a duplicate sitemap.xml file in your home directory.
iMav is offline
Old 06-09-2008, 02:34 PM   #10 (permalink)
Wise Old Mouse
mrintech's Avatar
Ya I am feeling proud that I joined your club
I used a wordpress plugin for generating XML site map. But now how I create a duplicate Sitemap?
Suggest any other free plugin service.
Also I read on Google that If you have more than 100 Links on a sitemap than for successful crawling break the sitemap. Now how to do this? Is their any sort of technique for braking sitemap?
mrintech is offline
Old 06-09-2008, 02:36 PM   #11 (permalink)
iMav's Avatar
Just copy the text file created (robots.txt) by the sitemap generator, it has a link to the original xml sitemap that google uses.
iMav is offline
Old 06-09-2008, 08:20 PM   #12 (permalink)
Wise Old Mouse
mrintech's Avatar
Samajh Nai aaya guru
mrintech is offline
Old 06-09-2008, 09:43 PM   #13 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
@mrintech
The plugin which you are using creates and writes to a sitemap.xml file. Just copy this file into your root directory. This is what iMav means. On the other hand, I am not sure if it will work. Could be just a overlapping of events that occurred with iMav.
Also, if you are moving database-driven website, you will have to export and import databases appropriately and also change the database connection details such as username, password, database name in the settings or config files!
Also, it it matters to you, you should backup the logs such as error logs, access logs, visitors stats. etc.
Backup your mails as well.
Best way to achieve all this id download a full backup of your site from your control panel.
Tip: Whenever moving your sites, create a index page that shall send "HTTP 503-service temporarily unavailable code; Try after some time" code to the spider and browsers!
गीक होना माँगता
victor_rambo is offline
Old 06-09-2008, 10:19 PM   #14 (permalink)
iMav's Avatar
COntact your host, he will be able to help you better.
iMav is offline
Old 07-09-2008, 12:02 AM   #15 (permalink)
Wise Old Mouse
mrintech's Avatar
Hey Friends,
I have already done what you all are saying when I installed all the applications. See the screenshot below:
The main thing is that I am not getting this everything was fine before 3 days. Google was indexing my site and pages properly, but suddenly it starts giving errors My account is with freehostia and my site is with http://mrintech.co.cc
I don;t know if this the problem with .co.cc Here's the link for Robot.txt file: http://mrintech.co.cc/robots.txt
Now pls tell me where's the mistake/problem?
mrintech is offline
KVM Switch... shivg33k Hardware Q&A 1 03-07-2008 02:32 AM
Website to accept domain name payments and send domain names Charley QnA (read only) 3 06-10-2007 06:45 PM
How to find Domain URL of a Sub Domain sridatta QnA (read only) 8 17-03-2007 09:17 PM
Domain Changing vln_0007 Software Q&A 5 02-05-2006 02:06 PM
