05-09-2008, 12:56 AM
Need Main Differences between G31, G33, G35 and P35 , P45 chipsets.
Hello friends,
I m compeletly noob  about these things(about chipsets). So, I want the differences between these chipsets (G31, G33, G35 and P35 , P45) . Is there any solid reason for upgrading a medium user like me from 946 board to p45 board. i generally use it for study, movie and a little bit gaming (with 8400GS)What the performance differences will I get? Plz, also suggest a low cost hybrid sli motherboard for intel processor. Should I wait or upgrade my system (heard that Intel is lowering their proc. prices this sept.)?
Thank U.
05-09-2008, 12:58 AM
Rubik's Uncle!!
Re: Main Difference between G31, G33, G35 and P35 , P45 chipsets.
05-09-2008, 01:02 AM
Sorry. It was done by mistake. Sorry again.
05-09-2008, 01:09 AM
Wire muncher!
Re: Need Main Differences between G31, G33, G35 and P35 , P45 chipsets.
Originally Posted by hayabusa_ryu
....Is there any solid reason for upgrading a medium user like me from 946 board to p45 board. i generally use it for study, movie and a little bit gaming (with 8400GS)..
NO there isn't! You are ok with what you haf for the uses you've mentioned. Unless you get a complementing processor and RAM it doesn't make sense to buy the high end boards or even something like G35 (up from 946 for the tasks you've mentioned).
Whats the difference b/w these chipsets? Higher mem. freq. support, some support different interface (DDR3), higher bus freq. (upto 1333) etc.
05-09-2008, 06:28 AM
I Always Prefer 1080p
09-11-2008, 04:15 PM
I Have Intel DG31 Core 2 Duo E7200 1gb DDR 2 RAM 160gb hard drive
Hey Can Any One Tell Which Graphics Card Is Best For Me ?
09-11-2008, 04:47 PM
AJJU
^ wats ur Budget ?
I love and Live to Design
10-11-2008, 12:08 AM
Wire muncher!
^^^ Sensible Question!
What is your budget and what do you intend to do? What games or software which require 3D acceleration would you be running?
11-11-2008, 06:42 PM
The Smaller Bang
Originally Posted by azzu
^ wats ur Budget ?
if you don't answer azzu and infra's questions, I would have to recommend you getting 4GB Dual Channel RAM and HD4870X2 GPU, air cooling and OCing your CPU if you want a hardcore gaming rig.
or
doing NOTHING at all if you want to have a graphics card to run Aero, since GMA 3100 can do that
Somewhere in-between a GPU for handling your current rig and enabling you to play all games and handle stuff like 3D then I recommend an upgrade to 2GB RAM first (which would cost you Rs. 600 - highly recommended and VFM upgrade), then a Palit 8600GT 256MB GDDR3 (Rs.3,500).
Apple iPad 2 16GB WiFi
18-11-2008, 07:28 PM
thanks
Search this Thread |
