Old 13-05-2005, 04:04 PM   #1 (permalink)
Default Help me to merge my two partitions!
I have two partitions on my hdd
c: has Win98
d: has winxp
i want to remove win98 from my PC and merge the 2 partitions
someone please tell me the step by step procedure to do this please!
A flea and a fly in a flue, were caught, so what could they do? Said the fly, \"let us flee!\" \"Let us fly!\" said the flea. So they flew through a flaw in the flue.
technovice is offline
Old 13-05-2005, 04:30 PM   #2 (permalink)
sujithtom's Avatar
Actually merging two partitons is child play if u use Partion Magic. But u have messed up a bit. Everything will be fine after u remove Win98 but when it comes to merging C: and D: merges to be just C: Tht means ur Win XP won't work anymore due to the wrong links. Not only tht all other installed programs on other drives won't work since E: becomes D: and so on. The only way u got (I think so but i am not sure) is to start from scratch i.e to format everything and reinstall OS after merging. Things will be easier if u a linux Live cd like Knoppix
http://geeksbay.monzilla.info - My Tech Blog :)
sujithtom is offline
Old 14-05-2005, 02:09 PM   #3 (permalink)
Just Do It
Charley's Avatar
@ Sujith - Is it possible to create another partitioned drive using the existing partitioned drives[C/D to E] without formatting it using the software mentioned above?
Charley is offline
Old 14-05-2005, 03:18 PM   #4 (permalink)
godsownman's Avatar
partition magic is not a free software so what should one do .
From the body of one guilty deed a thousand ghostly fears and haunting thoughts proceed !
Visit (http://www.meebo.com)
godsownman is offline
Old 14-05-2005, 04:43 PM   #5 (permalink)
Hi! once again u come to my rescue
It's not possible to remove win 98 without formatting the entire drive..right na?
i've got a program called norton ghost installed on my pc by my vendor...does it help in any ways?
Yep i think i can get a knoppix live distro!
What next?
