dear digitians,
requesting your valuable help to get it asorted.
Due to SOD, we are not permitted to install any database like orable/sql on our PCs, we are forced to use Access instead of other databases. but i am currently using MYSQL Community server which is not required installtion.
Now, we are getting DB dump in txt format which containts more than 2Lac data. With access, it takes time to run simple queries to get the results... so i will be using mysql.
Now, i need to convert the dump into a new table. i have tried with LOAD FILE but its not happening. I can not create a table to import cuz i won't have any idea about the dump contains
will be gr8 if i will get help for this.
