Old 31-08-2008, 10:31 AM   #1 (permalink)
The Black Waltz
Default How can I discharge stored up static electricity from my hands?
How can I remove static electricity stored in my hands? No wrist straps please.
#krow @ irc.freenode.net
Cool Joe is offline
Old 31-08-2008, 10:50 AM   #2 (permalink)
Cool G5's Avatar
Default Re: How can I discharge stored up static electricity from my hands?
Touch your hands to some metallic object for a few moments, the static electricity will be removed.
Cool G5 is offline
Old 31-08-2008, 11:29 AM   #3 (permalink)
is NOT a PC/Mac
debsuvra's Avatar
Exclamation Re: How can I discharge stored up static electricity from my hands?
Touching a grounded metal object once in a while helps to remove static electricity generated in the body.
If u want something professional then there are some professional devices available that control static electricity using alpha-emitting devices containing Polonium.
debsuvra is offline
Old 31-08-2008, 12:25 PM   #4 (permalink)
The Black Waltz
I read that touching a metallic tap is good. Is it really?
Cool Joe is offline
Old 31-08-2008, 01:43 PM   #5 (permalink)
@ beta testing: there's another thread going on with more detailed explanations -
http://www.thinkdigit.com/forum/show...d=1#post930411
pimpom is offline
Old 31-08-2008, 08:20 PM   #6 (permalink)
The Black Waltz
^Thanks for that
Cool Joe is offline
Old 31-08-2008, 09:20 PM   #7 (permalink)
You can touch a metalic object..but if the charge built on your hand is good enough then you might as well experiance a very small shock kind of feeling and you might as well see sparks between your hand and that object!!
You would never know that there's static on your body unless it is discharged after being in contact with another conductive or semiconductive material.
patkim is offline
Static Electricity Explained with Hardware Handling Precautions - A brief Tutorial topgear Tutorials 18 17-03-2009 06:09 AM
Save Electricity ! ! ! ax3 QnA (read only) 33 11-09-2007 03:06 AM
Monitor! Electricity! CRT or TFT ? Zen Hardware Q&A 2 18-08-2007 12:45 PM
Wht is How much ur Electricity Bill.....? satyamy QnA (read only) 12 18-12-2006 12:36 PM
MB's CMOS battery discharge problem sms_solver QnA (read only) 3 12-11-2004 01:42 AM
