give a try to Heatsoft Clone Cleaner Pro v1.00 Build1
Info i got is this :
One of the most common technical support issues with computer software and hardware companies today is the problem of duplicate files. You might have also come across the message Insufficient disk space while working with Mcft Windows. Duplicate files are one of the major causes of unnecessary use of hard disk space. Buying a larger hard drive can solve the problem but then you uses up the hard drive, you write them to CDR. More and more space is required. Another way is to manage your files well, find out duplicate files and delete them. This is why Heatsoft Clone Cleaner can help to free disk space.
Who can benefit from Heatsoft Clone Cleaner?
* Space Miser? Hate wasting hard disk space? People are amazed at how many duplicate files are on their computer and how much valuable disk space they take up. Clone Cleaner provides one of the fastest, most full-featured duplicate file finder in the industry.
* Internet users download files to their computers, duplicate files may exist and waste storage space. Especially using robot to download all files within the url, often can create a lot of duplicates.
* Programmers can use Clone Cleaner to compare their source code files so that they won't be confuse by same file name and duplicate files.
* Composers use Clone Cleaner in order to find the duplicate files especially those duplicated in content. Can you imagine the time they will waste in order to check each file by listening!
* Secretaries are in deep need to Clone Cleaner as they are asked all the time to find that file of a strange extension that there boss do not even know, so searching for unique files is so important for them.
* DBAs- Database Administrators need Clone Cleaner to check for duplications in backups.
* Students usually need to write reports. So they need Clone Cleaner in order to find duplications in word docs.
* Movies Directors certainly need Clone Cleaner to find duplicates of their pre-saved copies.
Main features System Requirements
* Find duplicates by a file name, file size and content
* Find files that have different names, and same content like "my.doc" and "Copy of my.doc"
* Fast checking for duplicates in Multiple drives
* Compare large files and large number of files fast
* Preview files before deleting
* Increase the hard disk space by deleting the duplicates
* Automatic group of files/folders occupying the most space
* Deleting duplicates files to the Recycle Bin
* Easy to use intuitive interface
* Extremely cost effective
Intel based processors 64 MB RAM or more
1.72 MB of hard disk space Supported Systems:
Windows 2000 Professional
Windows XP Home
Windows XP Professional
Windows ME
PRO version is a shareware program. It costs competitively at only $30 for a single user license. Version PRO have several additional features:
* Checking for duplicates in Multiple drives (Floppy,USB, Jaz Drive & Mapped Network drives)
* Ability to excludes subfolders from checking for duplicates
* Ability to save search criterias for quick access in future (like Favorites)
Identify and recover wasted disk space
Reduce backup time and media used for backups
Reduce file searching time
Minimize time used to unneeded virus scanning
Obtain more free space on "limited" resources, like notebooks
Remove duplicate files to eliminate synchronization problem
http://www.clonecleaner.com/HCCPROv1001.zip
OR
NoClone 3.0.5
Find and Remove TRUE Duplicate files
True Byte-to-byte comparison , not by CRC, utmost safe.
Search duplicate files, file portions by
byte-to-byte comparison, file name, simple fuzzy match
Search duplicate file contents regardless of file name
Smart marking of duplicate files by date, version, size, folder and file name pattern
Save search session
Export result list to CSV format
Show file versions and properties
Free disk space by deleting and moving duplicate files
Search duplicate pictures, video, songs, DLLs and any file types
Search local PC and over network
http://noclone-dl.com/NoClone.exe
or
http://noclone.net/NoClone.exe
or
http://noclone-dl.com/NoClone.zip
Guess both are Sharewares .....
