Old 30-08-2008, 11:56 PM   #1 (permalink)
Default Registrar for .in domain and webhost
Hi .. I need a good registrar for a .in domain and hosting for my business.
The registrar needs to be reliable and have a nice and easy user interface with the regular bells and whistles to control the website, email etc. as I will be controlling it myself to begin with. (I know it sounds utterly n00b but I am just starting to learn about cname and stuff)
Also need reliable hosting for the site and will only need max 50-100 mb in the beginning for some photographs etc of my products. Bandwidth can also be limited as not too many people will be visiting the site. For email I'll use gmail through Google Apps. Also I have another domain for another business and if the same hosting plan can work for that too it'd be great. What is this feature called?
cybertragic is offline
Old 31-08-2008, 12:16 AM   #2 (permalink)
हॉर्न ओके प्लीज़
victor_rambo's Avatar
Default Re: Registrar for .in domain and webhost
The feature that allows you to host multiple domais on the same account is addon domains. I suggest you go with www.whost.in, I am myself hosting there!
गीक होना माँगता
victor_rambo is offline
Old 31-08-2008, 11:06 AM   #3 (permalink)
Host4Cheap.org
Sukhdeep Singh's Avatar
You can get the domain registered from any reputed as 95% hosts will have an online control panel to change nameservers etc.
Right, for a starter website 50-100mb seems good enough Configuring Google Apps is easy and Google Apps does have instructions on configuring it for most common panel like cPanel, Directadmin, Lxadmin etc
The feature which allows you to have more than one website in one account is either Addon or Parked Domains
http://www.host4cheap.org/
Sukhdeep Singh is offline
Old 31-08-2008, 10:45 PM   #4 (permalink)
eWebGuru
ahref's Avatar
Look for the plan with addon domains, there are many reputable indian hosting companies providing hosting and domain, try searching in google.
Choose a plan which allows you to grow.
Windows and linux hosting at http://www.ewebguru.com
Get $50 per blog post PM me for details.
ahref is offline
Which U.S. based webhost to go for? aryayush QnA (read only) 8 27-05-2008 09:50 PM
Which is the best domain registrar ????? CadCrazy QnA (read only) 19 11-08-2007 12:06 PM
PHP MySQL Webhost prabhatmohit QnA (read only) 6 17-05-2005 08:16 PM
Webhost Config...Help ! cheetah PC Components / Configurations 2 09-05-2005 10:16 PM
Which is the best .in registrar? tuxfan QnA (read only) 5 24-03-2005 11:57 AM
