Old 30-08-2008, 10:06 AM   #1 (permalink)
Default CD copy protection ???
Hi,
We have developed one E-Learning Package. After Righting the content to CD. Member must not copy the content to hard disk. It must be copy Protected.
Anyone plz Help us with any solution. Thanks at advance
kiranbajpe is offline
Old 30-08-2008, 01:52 PM   #2 (permalink)
ayush_chh's Avatar
Default Re: CD copy protection ???
u can go for any of the softwares given here
http://www.cd-writer.com/cd_dvd_copy_protection.html
eXPerience is what a MAN learn's fROM.....
ayush_chh is offline
Old 31-08-2008, 08:44 AM   #3 (permalink)
Legen-wait for it-dary!
dheeraj_kumar's Avatar
You cant do that. Copying from the disk is just reading from the disc, and it cant be prevented. All you can do is to check whether the disk is present on the drive or not. There are many paid software which do the trick like securom, safedisc etc. You can also implement a small cd-check in your own proggie. like let it read some dummy file on all the cd drives present. if read successfully, start the app, else quit.
dheeraj_kumar is offline
Old 31-08-2008, 03:17 PM   #4 (permalink)
mad_max's Avatar
No luck bro alcohol can do any disk:S
mad_max is offline
Old 31-08-2008, 03:26 PM   #5 (permalink)
Violent serenity.
Psychosocial's Avatar
^True but Securom can ensure a little safety if sum dumb people use that CD who have never heard about 'emulation' .
Psychosocial is offline
Old 31-08-2008, 03:41 PM   #6 (permalink)
mad_max's Avatar
well hopefully the majority would be dumb and dumbers
mad_max is offline
Old 01-09-2008, 11:01 PM   #7 (permalink)
TooR
alok4best's Avatar
Exactly, who else will pay for an e learning package. .
Not to hurt anyone's feelings
I wish !!
alok4best is offline
What Copy Protection? Get AnyDVD dd_wingrider Technology News 2 20-02-2007 11:21 PM
Hacker: Blu-ray, HD DVD copy protection cracked shadow slayer 2007 Technology News 1 01-01-2007 05:41 PM
Copy Protection jit_914 QnA (read only) 2 07-05-2006 07:47 PM
word 2003 copy protection ratzee199 Software Q&A 5 17-02-2006 01:43 PM
copy protection vysakh QnA (read only) 11 08-10-2004 08:18 PM
