Hi
whenevr i try 2 update my sys using radarsync it sends some kind of information 2 some server but after that don't proceeds. I've tried it re-installing several times.
please delete your duplicate post..http://www.thinkdigit.com/forum/viewtopic.php?t=20426
if u did it by mistake, then ...watch your clicks bro
and if it was'nt a mistake..then it's a cheap way to increase your post count and get noticed
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
sorry for da mistake.
well, i wasn't knowing that my browser is submiting the post as it wasn't showing anything so this has been done by fault.
sorrry.
Finally,
OK so did u get any help from these.
In the RADARSYNC window, I found an option named "View Communication and update details", the following was written there.
Radarsync 2 Client
Loading compression Library...
platform: 1; MajorVer: 4
Loading hardware list...
Found: 52 known devices.
All devices were successfully detected
Sending software from a file...
Software updates are disabled!
Finally,
Radarsync 2 Client
Connecting to the server
Error during connection to the server
Disconnected.
Socket Error
Disconnected.
Help me PLZZZZ
well i havnt used radarsync yet but chk for these 2 entries in red.....Update Disabled meens u may have disabled it in Radarsynk itself or see if u have disabled Online Driver Update/installation
Socket error means its not able to establish connection to the server..chk your Firewall and Give Full/Server Access to the programm....
Wowe Buddy..ur radarsync Seems to be a very Dangerous Software ..i installed it for testing perpose and soon after installation my PC keeps on restarting for no Reason ........
Sorry btu I haven't modified anything in it in fact its completely a new thing 2 me?
SORRY for whatever happened with u I apologies.
But it can't be dangerous as DIGIT has provided it n DIGIT must not have provided anything dangerous.
I apologies again.
